Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-02-2022, 01:43 PM
Demarion Demarion is offline
Default Inserts on clips in a track.
I use inserts on a clip in a track to adjust sound. So far, so good. What steps are necessary to= solely apply those inserts to that clip, not the entire track? What steps are necessary to then= use inserts on other clips in the same track without affecting the other clips on that track? I'm told 'use bypass.' Only, that bypasses the adjustments I want where I want those. I used different tracks for different clips, only then I have too many tracks to track.
Old 04-02-2022, 02:12 PM
Default Re: Inserts on clips in a track.
There are at least 2 ways to accomplish what you want.
Option 1(how I would do it)
1-check to see if the same plugin is available from the Audiosuite menu(I'll call Audiosuite "AS" for the rest of this).
2-if it is, copy the settings from the inserted plugin and paste those settings to the AS version. Highlight the clip and hit the "render" button on the AS plugin. A new clip will be created with the AS plugin processing "baked in"(as long as the "Use in Playlist" button is highlighted on the AS plugin). Then remove the inserted plugin. If you do a lot of the same processing, you can save plugin presets in all plugins(AS or inserted).
Option 2-watch some videos on using "Clip FX" on youtube or better yet, grab a year subscription to Goove3.com as they have the best tutorials available
How to add more inserts into a track? papitopinillo Pro Tools 9 27 08-06-2019 04:30 PM
Moving inserts from one track to another Terry Wetzel Windows 2 03-31-2014 06:18 AM
Track Window not following track clips... TheEdster75 Windows 3 02-17-2014 04:42 PM
How do I copy inserts to another track gavriil1 Pro Tools 10 8 11-21-2012 01:15 PM
My LOUD beat clips all my inserts plugins and Vu-Meter! chavernac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-27-2010 08:09 PM
