Repeatable crash using Score Setup window
I've encountered a problem when trying to set two different options in the Score Setup window (File > Score Setup).
If I click in the field called Below Title and Composer, or the field called Below Chord Symbols or Diagrams, I get a pop-up window that says "This field requires values in the range of 5.00 and 999.00." When I click "OK", the window won't close. There's nothing I can do to get out of it and, as a result, have to Force Quit PT. Here is a screenshot: http://img21.imageshack.us/img21/329...setupcrash.jpg I'm hoping someone might be kind enough to give this a try and see if you can reproduce this. Thanks.
• Pro Tools LE 8.0.4cs2, Mbox 2 Pro • OS 10.6.5, Mac Pro 2 x 2.8 GHz Quad-Core Intel, 8 GB RAM • 7200 RPM System Drive, 10,000 RPM Audio Drive, 10,000 RPM BFD2 Drive |
Re: Repeatable crash using Score Setup window
Maybe someone from Digi Tech Support could verify this for me?
Yep same here...definitely a bug...I'd send this one to Digi.
Matthew |
Matthew,
Thanks so much for verifying this for me. I really appreciate it.
NP....I too required a Force Quit to get out of the error.
having the exact same problem. Only force quit gets out of it, but then I still can't adjust the spacing below title and composer. Definitely a bug with no workaround... Help digi!
Can anyone else check to see if this is a global bug, or just something specific to our systems? Digi?
I'll have this looked into asap...
I filled out one of those bug report forms (right after my initial post), for whatever that's worth.
Confirmed here also. Happens everytime.
Tamas Dragon
my blog:Tamas Dragon |
Opening Session Setup Window Causes Instant Crash | doubtful guest | macOS | 10 | 02-22-2013 07:01 AM |
Repeatable Crash using Air Plugs | dubaifox | Pro Tools 10 | 2 | 02-15-2012 07:33 PM |
Repeatable Crash (Just FYI) | themadarchitect | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-01-2011 01:34 PM |
Score Setup Crash | lyrad | MIDI | 3 | 12-02-2009 11:12 AM |
Repeatable crash | Submersible | Pro Tools TDM Systems (Mac) | 0 | 05-12-2003 02:51 PM |
