Hi.
The situation. When I create a vocal comp (dragging takes from other regions into one region), I'll press play to listen to the comp and the track is not muted but as soon as the line approaches the edit, the mute turns on and then back off once the edited audio passes. The process repeats at every time the cursor aproaches audio. And I can't seem to unmute it unless I hold the mouse down the whole time which is tedious. Can anyone help me? Thanks, Gilles |
You have somehow recorded mute automatization on that track. Just go to the mute viev & delete mute events manualy. (select the portion or the whole track & hit backspace.)
Good Luck
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
Thanks. I'll try that. Cheers.
Gilles |
I can't seem to get that to work. What is the mutes view? Is that where the "m" is? Also, If I highlight the section of music and hit backspace (delete on a mac), it just deletes the whole edit. These edited parts seem to play normal in the original unedited tracks though. I also tried to unclick "mutes follow groups" in "setup" "Preferences", but that doesn't seem to do anything. Anything else I can do?
Nevermind. I figured it out. All I had to do was choose the "mute" on the automation section and then move the line up with the little finger. duh!
Gilles |
Yep, if you have several autmatization regions (in Mute viev or what ever..) you want to delete, just highlite them & hit backspace.
By the way mute automation is rather useless in Pt
cause you can cut the region by selecting it and hitting b then mute with apple+M that way you can see the "mute automation" without going to sub views |
![]() Quote:
Seasoned users normally just use the mute automation, that's the way mutes are usually written using control surfaces. |
![]() Quote:
this will also work for volume, pan, and some plug automation (control+apple and click the control you've enabled)
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
Turning off Mute playback, and only mutes? | Farmer Dave | macOS | 4 | 02-24-2014 01:27 PM |
002 mute light not turning off | arbyis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-08-2008 07:42 PM |
Auto mute during record | jkatcher | Pro Tools TDM Systems (Mac) | 2 | 09-24-2008 02:08 AM |
Mute during auto touch? in 6.9 | lampmusic | Pro Tools TDM Systems (Mac) | 3 | 04-16-2005 12:15 PM |
auto mute during record | cubasteve | Digidesign Hardware & Software | 0 | 12-20-2000 03:55 PM |
