Old 06-05-2016, 09:07 PM
domdompompom domdompompom is offline
Default Limiter
I have applied a Maxim Limiter on my submix track feeding into my masterfader. Upon doing research, I found that having the limiter plug in with a ceiling between -.3db & -.5db is appropriate. While the threshold is good to have -2db or -3db. However, I my track does not sound loud enough compared to other songs I have heard and I do not believe it is loud enough for soundcloud, youtube, etc. Any points on what the settings should be?
Old 06-05-2016, 09:38 PM
JuanPC JuanPC is offline
Default Re: Limiter
http://duc.avid.com/showthread.php?t...hlight=Limiter
--->If you don't like what i wrote:
Click: JuanPC
Click: View Public Profile
Click: User lists^
Click: Add to ignore list.
Solved.
Old 06-05-2016, 09:55 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: Limiter
Stop slamming levels, get some good dynamic range, and it will all fall into place.
I mix a lot for VOD (You tube, Network downloadable episodes etc)
I mix at ITU BS.1770-3 specs. no problem with loudness.
IMDB
Old 06-06-2016, 10:08 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Limiter
While I don't recommend slaming levels, the mastering limiter from Massey is a great tool.
http://www.masseyplugins.com/#plugins/l2007
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 06-06-2016, 11:01 AM
Barry Johns Barry Johns is offline
Default Re: Limiter
Still my go to limiter to this day!
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 06-06-2016, 11:08 AM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
Default Re: Limiter
The Massey limiter is miles above any other limiter I have used. Now if he would only hurry up with the Windows AAX port......
Sign up for all things....AWESOME!
Kris
May the music move you
Old 06-07-2016, 10:22 PM
Default Re: Limiter
I see what you are saying, but can there be some more specifics to the settings of the Maxim Limiter specifically?
Old 06-07-2016, 11:08 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Limiter
No, you need to lower the threshold until it's loud enough for you
Janne
Avid Pro Limiter Vs Flux Limiter garnoil Post - Surround - Video 5 07-29-2014 06:47 AM
soft-limiter on mbox 3 soft-limiter.. overdriven tape saturation sound mjhann83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-07-2011 09:01 AM
LImiter on audiotrack Vs Limiter on auxiliar track cinetj General Discussion 2 07-15-2008 11:15 AM
Oxford Limiter vs TC brickwall limiter stargazer Pro Tools TDM Systems (Mac) 3 04-28-2006 12:32 PM
Waves L1 limiter vs. Focusrite D3 limiter??? Danny Caccavo Pro Tools TDM Systems (Mac) 1 05-01-2000 12:14 AM
