Elastic Audio on Guitars?
I was wondering how many of you do this. It seems if I don't do this, and I have other guitar tracks that play the same riff at a point during the song, they don't sound quite right. I've been playing the guitar for about 9 years now, and am on time pretty well.
Is there something I'm missing? Or do many people use EA on guitar tracks to? |
Re: Elastic Audio on Guitars?
I use it if I hear a spot where 2(or more) guitars don't lock well. With EA, your safest route is to duplicate the track and EA the dupe(sometimes EA causes artifacts). Choose the Polyphonic setting. I use it on my bass parts too(Monophonic setting) to lock it to the bass drum. Also, BGV's can be tightened up(like when a word ends in "T" or "S" and someone is off time a tad)
If you want it to be tighter, but not so tight that it's perfect, you could also do things manually, looking at the waveforms to see what's really off, and what's only a tiny bit off.
albee1952:
Thanks, so I am not the only one that does this :) nst7: What do you mean by "manually"? |
I've used EA on guitars a bunch. I'm usually just doing small tweaks on individual notes/hits. A good example was the big ending hit on a song that the guitarist had five tracks going. He was really good at doubling himself but the last hit was after a bit of "free time" wailing so it was hard to catch it right on. I just enabled EA on the tracks and manually pulled the notes into position.
I have experimented with extracting a groove template from one guitar line and using that to "quantinize" a second guitar to it. I did it in small chunks and it seemed to work OK, but that was a while ago and wasn't anything but an experiment. (I'm not big on militantly tight doubling anyway but I might try it again if I'm doing doubling on some Metal stuff)
"Sometimes having limits keeps you sane"- Albee1952 |
He means setting your track to Warp view, use your grabber, and "manually" position the note.
PT10 elastic audio unable to analyse audio files | chinopepito | macOS | 8 | 03-30-2013 11:03 AM |
Render elastic audio alert when not using elastic audio! weird! | jjboogie | macOS | 7 | 03-26-2012 09:01 PM |
Using Elastic Audio match to tempo without affecting the audio | Silvio | Pro Tools 9 | 5 | 06-21-2011 09:41 PM |
Elastic Audio on Multi-Miced Electric Guitars... PLEASE HELP!!! | dglennjr | Pro Tools TDM Systems (Mac) | 13 | 05-09-2009 03:30 AM |
Elastic AUDIO, or Elastic TIME? | SoundWrangler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-13-2007 11:21 PM |
