Moving markers with audio selection
Is this not possible? I've been able to cut and paste the markers to a new location, but the audio does not follow?
I get a message saying "operation is not currently supported for conductor rulers" Use cut copy paste clear. This does not work either, and what exactly is "clear"? I even tried the Dynamic Transport to see what would happen, and nada.. PT 7.4cs5, OS 10.4.11
MacBook Pro 15in, 2.3gHz,i7 PT 2021.x PT12.8.x |
Re: Moving markers with audio selection
I think maybe you're not including everything in your selection to copy over, as I have no problems achieving this. I can highlight a portion of an audio region and "shift + click" my marker bar to include my markers, then I copy the selection and jump to another bar and paste everything. Audio and markers are both pasted. Whatever you want to be copied needs to be highlighted, including the audio.
I'm getting one or the other. If I paste in the marker ruler, the markers paste. If I paste in the edit window, the audio pastes.
I can not get both at the same time. I select all the audio regions, then shift + click the markers ruler, then copy. Can't imagine why this isn't working, is there some preference not turned on? I've tried it in Grid, Slip and Shuffle mode.
Also tried Colors on & off, Timeline follows edit on & off, everything I could think of...what gives?
when you select your paste point are you again shift clicing in the marker ruler?
this should work b.o.l. e
ihatetyping |
Just tried it. So you you have to click once in the playlist area, then shift click the marker ruler, copy, then click in the paste point in the playlist, shift+click the marker ruler, and then paste, and it works???? WOW So there's no way to select audio, shift+click the marker ruler and drag to a new location? If I try this, I get the message that the "operation is not currently supported for conductor rulers" PITA!!
selection snaps to markers? | djcyph | Pro Tools 10 | 3 | 12-05-2013 01:30 PM |
Moving Selection By Selection Length | weezerboy | Pro Tools TDM Systems (Mac) | 14 | 09-23-2010 03:06 AM |
NEED HELP QUICK "MOVING MARKERS WITH THE AUDIO DOWN TIMELINE | dkstudios | Pro Tools TDM Systems (Mac) | 2 | 06-02-2008 04:40 PM |
moving audio & markers | mixerboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-15-2003 12:16 AM |
how to include the markers themselves in an edit selection? | c-post | Tips & Tricks | 1 | 10-28-2002 02:07 PM |
