What is this distortion?
Last night i opened a session (call it session 1) i'd been working on and there was hideous distortion everywhere, any track, with or without plugs.
Opened up a different session. Same problem I trashed prefs, same problem. Turned interfaces on and off. Same problem Opened up a simpler session and it worked fine, no problem. Went back to session 1, it worked fine. Today, I had cause to trash prefs again. Opened up session 1 and the hideous distortion was back. ANy ideas what's going on here? Thanks, Rob Mac Pro 2.66 OS 10.4.9 7G Ram PTHD 7.4 cs2 Lynx Aurora8 UA 2192 |
Re: What is this distortion?
The only time I've ever had this problem was when my hardware buffer size was set too low. Try increasing it to 512 or even better to 1024.
Adam Miele PulseMusicNY.com [email protected] (212) 358-7900 |
Try reseating the flex connectors on the cards.
I would also call Digi, you may need new PCI-E cards with a chip update to fix a bus speed problem on Mac Pros. . .
...for system configuration info see my profile (Click on member name) |
Distortion | DaleB | macOS | 2 | 11-09-2012 04:47 PM |
RMS and distortion. | yamahadrums | General Discussion | 4 | 11-06-2012 11:21 AM |
distortion help | robgreen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-12-2005 02:59 AM |
002 Distortion | tg4878 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-19-2004 07:47 AM |
Distortion | Mark Tandy | Digidesign Hardware & Software | 2 | 05-17-2001 10:13 PM |
