Old 11-15-2021, 10:36 PM
drumbreaker drumbreaker is offline
Default Avid Complete Plugin Bundle - Monterey Compatibility
Forgive me if there is a thread that has an answer already, but after searching here not finding much info other than confirmation...
Avid Complete Plugin Bundle does not work on Monterey. Is there any discussion anywhere from Avid on when this will be fixed?
Thanks
Old 11-15-2021, 10:44 PM
Default Re: Avid Complete Plugin Bundle - Monterey Compatibility
Probably at the time when Monterey is supported. Currently it is not.
Old 11-16-2021, 12:30 AM
Thanks for the reply Janne. We will be waiting! Cheers from LA to Finland
Old 11-16-2021, 12:31 AM
Thanks. It is fridge temperatures here now
Old 12-08-2021, 05:08 PM
This seems to be a timely opportunity to chime in here. I imagine I'm not the only one that wants to smash my computer screen after downloading the latest PT and being prompted to remove my incompatible complete bundle to the Unused Plugins folder!
My question now is has anyone seen any further info here on the DUC on what timeline we are looking at to get the complete bundle to work on Monterey? Many of us use Complete Plugin Bundle in every session so we're still stuck on the old machine until they patch this.
Also has anyone discovered any workarounds to get these going temporarily on Monterey?
Cheers!
Old 12-08-2021, 07:22 PM
BScout BScout is offline
Cheers!
I did a pull on all the Pace Eden (iLok) versions of current plugin licenses on my system.
All the plugins in the Complete Bundle are on 5.0.0 GM.
All plugins that use 5.2.0 GM or later appear to be working.
Current version is 5.4.1 GM.
This may be the issue -- and there'd be no workaround for that. The plugins will need to be recompiled using a later Pace Eden wrapper.
I'll check again tomorrow on our Monterey test system if I can narrow down what Pace Eden version is the breakpoint. Just know Cargo Cult Spanner (5.2.1 GM) and PhoenixVerbSurround (5.2.0 GM) were working. But Stratus/Symphony do not and they are 5.0.2 GM.
Old 12-08-2021, 07:36 PM
off the wall's Avatar
Why do the Avid Compete Bundle plugins work fine on PT 2021.12 under Big Sur and lower then? Is there a different version of PACE that is installed under Monterey?
offthewallproductions
Old 12-08-2021, 08:00 PM
I believe this might have to do with the "user-mode" version of Pace. In essence, an Apple macOS restriction to prevent drivers from running at a lower level in the system as a security feature. Current iLok software could determine which mode it runs at once installed. So install on Big Sur, iLok runs at kernel-mode. Install on Monterey, kernel-mode fails so it runs as user-mode.
And if a plugin wasn't compiled with the user-mode ability (whenever that was released as part of the PACE Eden toolkit), it fails authourization on user-mode systems.
[This is all conjecture but seems to fit with what is observed. And I know Monterey restricts drivers]
Old 12-08-2021, 09:15 PM
Mods, would you please consider escalating this issue? At least to find out of a simple recompile with latest PACE would fix this? This simple issue is keeping many of us from being able to use our new machines. It would be highly appreciated! Thanks for your time
Old 12-08-2021, 10:07 PM
You must be new to Pro Tools? Do you not think Avid know that their DAW does not work on a whole new generation of Mac products and that's not kinda an issue for users? Hard even for Avid to miss this. They know, and will be working on it. And Avid being Avid, they will operate how they have for decades and you are very unlikely to hear any estimate of when fixes will happen. Complaining here or asking others to complain for you is not likely to change anything.
The transition to new Apple silicon is going to involve hassles, and this may just be start of some of the pain (wait until some but not all plugins start moving to native code).
Avid Complete Plugin Bundle renewal musicman691 Licensing & Accounts 4 04-23-2021 04:24 AM
Installation Avid complete plugin bundle [Résolue] Msim12 Le Forum en Français 9 07-07-2020 12:08 AM
Avid Complete Plugin Bundle Renewal Issues atticaaudio Licensing & Accounts 8 06-01-2020 03:02 PM
Avid Complete plugin bundle jesele Licensing & Accounts 3 02-06-2020 12:02 AM
Avid Complete Plugin Bundle / Fail to load Zergei AAX Plug-ins 1 03-16-2018 11:54 PM
