Old 12-13-2010, 09:29 AM
NewdestinyX NewdestinyX is offline
Default M-Audio Profire Lightbridge
Is there any secret to getting the MAudio Profire Lightbrige Analog outs to work in PT9?
I've checked and unchecked the 'mirror' Spdif to Analog outs to no avail. I've done the driver install EXACTLY in the order they specify. Uninstalled and tried again. NO luck. I can't get PT9 standard to pass audio to the analog outs or the headphones which I assume is the same as analog outs. Anybody regularly using this piece with PT9 that could help me?
Thanks,
Grant
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard
Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS
Old 12-13-2010, 09:30 AM
getz76 getz76 is offline
Default Re: M-Audio Profire Lightbridge
Mine works fine. Check your Pro Tools I/O.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 12-13-2010, 10:11 AM
What do you mean by 'check my I/O'? For what, Getz? And thanks!
Old 12-13-2010, 11:56 AM
See page 83 of the manual.
Old 12-13-2010, 12:05 PM
Default
Manual? What manual PT 9 or profire? ;-)
Online?
Old 12-13-2010, 12:08 PM
Just send me all your gear and I will set it up and return it to you. I promise.
Old 12-13-2010, 02:31 PM
LOL!!!. So you meant the ProFire's manual page 83, Getz>
Old 12-13-2010, 04:49 PM
Well unless you mean to imply that on page 83 of the PT9 manual (the Profire manual doesn't have that many pages) I'm gonna find a way to 'remap' channels.. then the answer is that I have to again, just like with my MOTU system, DEFEAT certain input/output paths in the hardware's app. My problem was that I had all 4 ADAT banks enabled and the SPDIF and Analog outputs are at holes # 33-36 which OF COURSE -- aren't available in PT9 Standard!!!!
Does anyone else find it ironic that in Avid's LESSER software, M-Powered 7 and 8 ALL 34 ins and 36 outs of a ProFire LightBridge were AVAILABLE!!!!!!!! In that way -- MPowered was a 'superior' piece of sofware than to even LE -- and now it reminds me of why Avid had to create their 'own' software for the M-Audio products which were BIG on LOTS of IO. If I open PT Mpowered 8.0.4 right now and plug in my Lightbridge I have '34 ins' and '36 outs' available to me. But NOT in the software that REPLACED Mpowered 7/8.. Isn't that somehow - just WRONG!!??
Old 12-13-2010, 05:21 PM
Hotcrazyfruit Hotcrazyfruit is offline
PT9 only supports 32 inputs and 32 outputs
Core i7 920 OC'ed @ 4.0 GHz (200 X 20)
12 GB Patriot Viper Extreme
Asus P6T
OCZ Agility 64 GB SSD
Hitachi 1TB 32 MB HDD
WD Caviar Black 500GB
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
Fender Super Champ XD
Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet
Old 12-13-2010, 05:32 PM
necjamc necjamc is offline
PT M-Powered 7 and 8 did not support any more than 18 I/O. And no offense, but other than Machine Control, Ethernet Controllers, and The DV toolkit option, there really was no difference with M-Powered/LE. I have both as well as 9. I don't about the Lightbridge, but with my 2626 I always just routed the spdif and optical b last because PT sees the first 18 regardless of what they are. In PT 9 it sees the first 32, anything after is ignored. (should be.) So if you route the outputs you don't need to the end in the control panel, the ones you do need should be all available.
[IMG] code is Off
m-audio profire lightbridge protools 9 patcram Pro Tools 9 7 11-28-2010 05:17 AM
M-Powered 8 + M-Audio Profire LightBridge Zergei Pro Tools M-Powered (Win) 0 04-26-2010 11:07 PM
PT LE & M Audio Profire Lightbridge jakas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-06-2009 07:12 AM
PT 7.3 with M-Audio ProFire LightBridge SteveD@DAWPRO Pro Tools M-Powered (Win) 14 01-23-2007 03:28 PM
M-Audio ProFire Lightbridge KamilFX Pro Tools M-Powered (Win) 13 11-20-2006 12:34 AM
