Old 06-27-2022, 02:50 AM
gugu gugu is offline
Default GAIN plugin clip by clip not available
Hi All,
I noticed that the option of clip by clip process isn't available anymore in 2022.5
Really weird as it's ok with Normalize which is the same plug
Am I the only one ??
thanks
File Type: png Capture d’écran 2022-06-27 à 11.47.41.png (84.4 KB, 0 views)
Old 06-27-2022, 05:32 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Default Re: GAIN plugin clip by clip not available
Probably worth checking the previous version(s) of Pro Tools if you have them in your Applications folder? However, maybe the behaviour is caused by the actual plugin itself?
I used to use the Gain Audiosuite a lot a noticed some changes (somewhat negatively as I was concerned) a good few versions back. I seem to remember chiming into a DUC thread at the time.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 06-28-2022, 01:23 AM
May be this "bug" is there for a few versions back but I didn't notice.
Again, the weird thing is that normalize (the same aax plugin) is behaving normally
gugu
Old 06-28-2022, 05:11 AM
This was the issue
https://duc.avid.com/showthread.php?t=393573
Some posts in this thread might help too?
https://duc.avid.com/showthread.php?t=398251
Stephen
Old 06-28-2022, 07:13 AM
Thanks Stephen but no, only the "clip by clip" option is not available. everything else works as it should.
I replaced the plug in by older versions (even back to 12.5) with no success
Old 06-28-2022, 09:47 AM
Yeah same issue here with gain. By comparison, normalise has clip by clip as expected.
Must be a bug?
Stephen
Old 06-28-2022, 12:54 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Just use entire selection and individual files.. isn't that it?
Logic and reason tells me that is same as clip by clip (since years of using Gain plug-in)
Sent from my Pixel 6 Pro using Tapatalk
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 06-28-2022, 01:58 PM
audiolex1 audiolex1 is offline
I can confirm that is also the case in PT 2021.12.
Changing the selection type doesn't matter. Entire selection is the only option.
Considering how old that plugin is, ported over and over again, I wonder if it was always like that.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
HTML code is On
Is the Clip Gain the same as a Trim Plugin? SpinningDisk Pro Tools 11 14 09-15-2022 05:07 PM
trim plugin ? clip gain? icamusic AAX Plug-ins 9 10-04-2017 01:19 PM
Adjusting Clip Gain On More Than One Clip Blank Frank macOS 17 05-15-2015 06:34 PM
Gain plugin bug? Writes distortion to start of first processed clip iain_m Pro Tools 10 18 06-03-2013 03:41 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
