Old 05-27-2022, 01:10 PM
smurfyou smurfyou is online now
Default Re: Destructive Punch File Length
Originally Posted by reichman View Post
Woah! Discontiguous destructive punch zones? My head is spinning. Cool idea. DP stem recording (even on single system mixes) is still an essential part of my workflow.
Yeah it’s different than what we’re used to. It just seems like it should be possible. As long as the system knows which regions are enabled it can plan for it. Maybe I’m oversimplifying it or maybe the way they configured the read/write buffers isn’t easily modified.
FWIW I actually don’t use DP anymore because I got tired of fiddling with it. I’ve been living dangerously and using Destructive record for a few years now. Would probably go back to DP if it was improved.
~Will
Old 06-03-2022, 05:44 PM
fork-media fork-media is offline
interesting thread- destructive record is part of my work flow too. One last time to check and fix as well as create the stems at the same time.
I can still make PT crash all day long with it tho.
Just redo the exact same 'punch in' ( not DP ) and bingo I'm looking at the crash reporter.
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
Old 06-03-2022, 09:26 PM
audiolex1 audiolex1 is offline
I don't know if dis-continuous Destructive Punch is possible. It is really a Dubbing Mix feature with stems.
Maybe it is, but I don't like split reels in the same session. Probably because of the days of session corruption, but also when operating at a faster pace, Pro Tools editing, and console mixing there is just too much room that something can happen later in the session.
Rogue curser, finger brush on a key command, accidental automation write to end. Granted these were all things that happened a decade ago, but they did happen.
Also, I think there has to be dedicated hard drive space allotted for the destructive record/punch. As hard drives work, they write data to free space so if there isn't a dedicated file, it has to create a new one.
I remember the old Tascam HHD recorders and we had to record a little bit in front of the start point and a little bit at the end of the start point to create a dedicated space for punching.
So when you punch in, the space on the hard drive is it is recorded is always the same. Its kind of like if it were tape.
You punch or record, previous data is gone.
But your drive space stays the same. You can punch 1000 times on it and your drive space will stay the same.
Its primarily a dubbing feature, but if you want to keep people on their toes, destructive punch will keep the best of the best performances and there won't be anything to go back to.
Just like the days of tape.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 06-05-2022, 11:21 AM
Right but that's a pretty trivial thing to do nowadays. That's kind of what I meant when I said you can designate certain clips as such.
The previous generation Fairlight systems (pre Blackmagic) had a "Tape" mode. You could make a time selection on any number of tracks and create destructive tape clips. So on your rerecord tracks it would create a "blank tape" exactly as you described. Just an empty WAV file written to length. Then you could punch in at will. So if I had a 7 segment show I created clips for each segment.
~Will
HTML code is On
PT 12 HD Destructive punch bug? Sndnerd Pro Tools 12 0 09-28-2016 08:13 AM
Write/ preset a file container for re-recording process via destructive punch, [email protected] macOS 0 10-09-2015 06:17 PM
difference Destructive punch Rec and Destructive Rec [email protected] Pro Tools HDX & HD Native Systems (Mac) 4 06-19-2013 03:47 PM
PTX & Destructive punch Cryos macOS 8 03-11-2012 05:47 AM
Destructive Punch too destructive! Stylin' Audio Pro Tools TDM Systems (Mac) 6 06-22-2009 07:54 AM
