M-Audio Transit not going to 96?
I just installed M-Powered 8 with the M-audio Transit USB interface for my MacBook Pro. I installed the latest drivers for the Transit and also updated the lasted "crucial" update for M-Powered 8. For some reason when I create a new session it only has 44.1 & 48 kHz as an option. The Transit says it's a 24 bit 96 kHz audio interface so the only thing I can think of if it's dependent on the software determines how high the sample rate.
Here's the spec's: 15" MacBook Pro: Mac OSX 10.62 3.06 Ghz Intel Core 2 Duo 4 GB 1067 Mhz DDRM RAM Pro Tools M-Powered: Version 8.0.3cs1 M-Audio Transit: software: 1.8 Firmware:1.01 |
Re: M-Audio Transit not going to 96?
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
If it's anything like Fast track pro's drivers control panel, you would have the option of selecting less inputs and output to give you the 96k sampling rate. I had the same issue until i deselected less inputs on my unit.
John Pro Tools 12.5 Macbook Pro & Windows 7 Ultimate 64 Bit |
I haven't checked in the Transit control panel yet but I will check it out later this evening. That must be the problem.
It seems odd that this would be the case because I have a FireWire 410 interface and I have never had to go into the control panel to alter my sample rate selections, I have just been able to open a new session and I have all the sample rate options upon opening pro tools. It would be great if someone with a Transit could chime in as well as I curiously to hear their thoughts. |
I think the reason why is because usb is not as fast as throughput as firewire is so your firewire device can handle all your inputs and outputs by default. Just my $.02
You guys were correct about the settings in control panel. Very odd but oh well its up and running now. Thanks!
The Transit supports 96kHz only as input OR output.
You can select this easily from the hardware setup within Pro Tools before starting a new session. Because USB 1.1 is not fast enough to do muliplex audio output at that sample rate.
last: PT11.3.1 |
M-Audio USB Transit & M-Box | contrabasc | Pro Tools M-Powered (Mac) | 4 | 08-24-2010 07:40 AM |
M-Audio Transit | ngattaserge | Pro Tools M-Powered (Mac) | 5 | 05-19-2009 06:08 PM |
M-Audio Transit USB w/PT? | natives | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-14-2006 08:25 PM |
m-audio transit | technician | Pro Tools M-Powered (Win) | 2 | 05-15-2005 09:14 PM |
M-Audio Transit USB | erik c | Pro Tools M-Powered (Mac) | 1 | 04-13-2005 07:46 AM |
