Old 01-27-2023, 12:22 AM
alldayjay alldayjay is offline
Default 16GB or 32 GB unified memory for Pro Tools?
I am currently using Pro Tools for recording and mixing on a mid-2012 MacBook pro with 8GB of memory.
It works but I constantly get CPU errors and some larger sessions are basically impossible to run through smoothly. I am looking to upgrade to a 14-inch MacBook pro with the M2 chip but I have questions about the specs I need.
Do I need 32GB of unified memory or will I be fine with 16GB? Whatever option I choose needs to be good for a minimum of 5 years. I use a lot of third-party plug-ins but my sessions typically don't exceed 50 tracks. That includes audio tracks, Aux tracks, etc.
Do I need 10 core or 12 core CPU? 12 core is more expensive but I don't want to spend the extra money if that isn't relevant to what I doing.
Any answers or insight anyone can provide would be extremely helpful.
Old 01-27-2023, 12:47 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: 16GB or 32 GB unified memory for Pro Tools?
Hi, welcome to the community.
Memory on Mac cannot be upgraded so buy as much as you can afford.
Janne
Old 01-27-2023, 07:15 PM
sw rec sw rec is offline
64
Old 01-27-2023, 11:36 PM
Sardi Sardi is offline
More information will yield better answers.
What sort of plugins? Some chew virtually no CPU. Others are hogs.
Are you using VIs? If so, what type? Sampled based or synths?
16Gb will easily work assuming you’re NOT intending on using large samples based VIs. That’s where your memory bottleneck will occur. Even then, one can argue that streaming from modern disks is probably fine unless you want every patch to switch instantly.
If you want the machine to last a minimum of 5 years, I’d opt for more RAM. Computers are the centre piece of your studio. Stretch your budget as far as you can.
Do I need more unified memory or more cores? Mixologist Pro Tools 23 02-14-2023 02:25 AM
Pro Tools with Dell XPS 8700 Desktop PC Intel Ci7-4790 16GB baxteradio Windows 0 07-25-2015 02:33 PM
critically low on memory...? WTF? We have 16GB. KingTor macOS 8 11-09-2012 09:09 PM
Can Pro tools use 16gb ram on a Macbook Pro late 2011 trajan24 macOS 2 12-20-2011 10:02 PM
Can Pro tools use 16gb ram on a Macbook Pro late 2011 trajan24 Pro Tools 10 9 12-19-2011 09:12 PM
