Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 02-03-2022, 04:25 AM
daxtrader daxtrader is offline
Default MBOX Pro (3) Power Supply
Hi all, I need some help please. I need a replacement power supply for my mbox pro.
After hitting forums, looking up the mbox3 tech spec, finding as much as I could I understood that I needed a
"9V, 4A, 36W, Plug-In Power Supply (Center Positive 2.1mm x 5.5mm plug)"
They are not easy to find.
But I found one!!
After ordering it, I received it this morning.
But it doesn't even fit!
So which part did I get wrong?
The plug is definitely the correct spec based on the above.
Thanks
Old 02-03-2022, 06:10 AM
Jay_uk Jay_uk is offline
Default Re: MBOX Pro (3) Power Supply
In UK and they come with a barrel to accept a 2.5mm pin, which is wrong. (too tight)
The Mbox 3 pro has a 2.8mm pin on its housing
INPUT: 100-240V, 50/60Hz, 1.5A OUTPUT: 9V, 4000mA, 36VA
Note its also a 4amp (4000ma) output
So i had to get a barrel with an inner 2.8mm hole, to replace/solder the 2.5mm one. Cant recall the outer barrel size but I think 5.5mm is correct.
https://duc.avid.com/showthread.php?t=380242
Old 02-03-2022, 06:19 AM
Here you go.
https://www.ebay.co.uk/itm/281821358008
WTB power supply for Mbox 2 Pro albee1952 Buy & Sell 3 05-21-2021 05:20 PM
Mbox Pro power supply Synapsis FireWire & USB Audio Interfaces (Mac) 2 05-21-2021 05:14 PM
Mbox Pro power supply BazPD FireWire & USB Audio Interfaces (Mac) 0 12-16-2017 05:39 AM
Best way to power supply a Mbox 2 Pro mboxpro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-26-2007 01:54 AM
MBox Power Supply WheelSpoke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-11-2002 09:23 PM
