Re: CPU time errors
Thanks for your input Brent.
I am running the latest firmware and I reinstalled it this morning. I have already been through some quite considerable steps to cure this and some other problems (type 2 errors mainly) including completely replacing my system drive along with multiple reinstalls, pram zaps, new core card, new 192, etc etc. I have repeated the steps you suggest (I had not rebuilt the desktop before) but I am unfortunately still suffering from the same errors. The plus side is that I can work, it's just that I cant use any RTAS. Obviously I must to be able to run RTAS if I need to, but more importantly, I am worried that there is an underlying problem with my system that could surface further at an undesirable moment. It may be worth noting that I gave the system to my dealer for a day for testing. He double checked it, and tested it very thoroughly. It behaved perfectly. I had an error the following day back at the studio. The only factor that has changed is the presence of the procontrol. Could actvity on the ethernet port be causing a system problem? J |
Re: CPU time errors
1-Bad Ethernet Cable or Hub (if using one) 2-Bad Ethernet port 3-Bad ProControl From an earlier post, it seems that you have eliminated #1. If all other Ethernet activity seems to appear fine (if using a cable modem or connected to a network), then that should take care of #2. In regards to #3, you should run the Ethernet Loopback test on PC and check the results. The instructions on how to conduct this test are located in your PC Reference Guide. Brent |
Re: CPU time errors
Thanks Brent. I have already eliminated the type 2's by replacing my scsi card. The only errors that remain are the CPU time errors ( -6031).
I have already run the loopback test and achieved 0% errors. As my dealer found no errors when he tested the system I am hoping that it runs ok without the pro control. Obviously as the errors are intermittant, and he only had it for a day, this result is not 100% reliable. Unfortunately I am unable to do any extensive testing without the pro control as I am booked up solid at the moment. I am also worried that although the procontrol may be provoking the problem, it may not ultimately be the cause. I guess I should try connecting a different pro control and see if that cures it. That would identify the fault as being with the system not the pro control. Now where to find one... [img]images/icons/smile.gif[/img] Jack |
Re: CPU time errors
Why is your DAE Playback Buffer set to 4? I think that is rather high for the sys that you are using...bring it down ot 2 or even 0. |
Re: CPU time errors
I dont usually leave it at 4. It's just that I have been doing a lot of testing and have changed it a lot. In fact none of the playback engine settings seem to be affecting this problem at all.
J |
Re: CPU time errors
I have run some further troubleshooting tests with another mac, another pro control, another 192, and no process card. The errors are still there. So...
It is not The mac The pro control The core card (already replaced) The process card The Interface Any of the cables Which is good really, but this means the problem must be somewhere in the software. I have tried reinstalling more than once. I have tried a new system drive. I have tried different extension sets. I have had the excellent tech at my local dealer make sure that I'm not just being stupid...so what is the problem here? The software is roughly as follows. If anyone sees anything that rings alarm bells please shout loudly. os 9.2.2 pt 5.3.1cs3 logic 5.3 for os9 retrospect express toast titanium jam recycle 5 qt5.0.2 pro I also have various third party plug ins but I am still getting errors when they are disabled. What could be upsetting RTAS? Jack |
Re: CPU time errors
It has been seen where Toast causes problems (especially if multiple versions are installed). Therefore, eliminate the Toast extensions from the system and see how things go. If Jam has any extensions specific to itself, disable those as well.
Brent |
Re: CPU time errors
Thanks Brent
I have had those all disabled. No joy. Jack |
Re: CPU time errors
have you tried 5.1.3cs7... may be of no consequence but probably worth a go
Re: CPU time errors
I have now taken the original system drive, reformatted and installed 9.2.1 from the cd. I have reinstalled pt 5.3 and tried that with nothing else on the system at all. It is still giving me errors! What is going on here? If anyone is not at AES can they have a think about this please.
The os makes no difference. The system drive itself makes no difference. With or without scsi makes no difference. Different pro control makes no difference. Different Mac makes no difference. I've taken out all usb etc etc. Running off ide/firewire makes no difference. Different versions of pt make no difference. I have had a new core card. Removing the process card makes no difference. I have tried a different 192. I have replaced all cables. I am confused. Is this a fault or an issue? Jack |
Errors ALL THE TIME...PLEASE HELP!! | FiO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-14-2008 03:04 PM |
-6101 errors all the time | blastula | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 03-03-2007 07:16 PM |
-6086 errors all the time | powderhound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-04-2005 12:12 PM |
H/W Buffer Errors ALL THE TIME | mudnoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 10-15-2004 02:54 PM |
HW Buffer Errors on 002. ALL THE TIME... | byteme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 07-23-2003 02:45 PM |
