Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 05-18-2021, 11:23 AM
Maris Maris is offline
Default Headphone output heavily distorting on C400
Hi all,
I have my Fast Track c 400 bought used fro some 4 years now. But I have barely used it because I bought it for possible remote recordings. Now after some time I put it on a thorough test. My setup: Windows 10 x64, C400 with 1.1.7 x64 drivers. Everything worked just fine, except one thing: the headphone output had an awful distortion when listening to any commercially released music. That is to everything where the peaks frequently reach 0 dBFs. At the same time both Line outputs sound briliantly. I connected the C400 to 4 different PC with Win 10, Win 7, installed the previous drivers 1.1.5, used different headphones (Sennh. HD 600, A-T ATH-M20) but the situation never changed. The single way to reduce the headphone distortion was gradually reducing the Software Return volume. But that of coarse reduces the Line Output as well what I don't like at all. And with acceptable distortion the headphones volume was rather low.
Has anyone expierenced headphone distortion when listening to quality full scale recordings (Pop music) with C400, C600, or other AI from Fast Track series? I guess that my C400 has got simply some electronic fault. It could not be a driver's fault, because then anyone would blame them for that?
I used different DAWs for this test as well: Nuendo 6, Sony Vegas 12, Sound Forge 11, VLC player, switched from Windows Classic drivers to ASIO drivers. Nothing helped
I'm sorry for my long post!
Maris
Maris, Sound Recording Engineer
Old 05-19-2021, 05:50 AM
Default Re: Headphone output heavily distorting on C400
Sounds like the headphone output is shot. You could get a new(er) interface(and I would avoid M-Audio as they are mostly crap IMHO), or get a headphone amp
Old 05-19-2021, 10:08 AM
Yes, I think you are right. The headphone output is shot. But I don't think that M-Audio USB AI are crap. On the contrary- most other are crap. And why should Avid choose M-Audio as a partner?
And yes, the right solution is to attach a headphone amplifier to the secondary Line Output.
Most of the USB Stereo AI I have had my hands on have had all sorts of issues. I think the best and most reliable are M-Audio, Focusrite, Steinberg, Presonus, TASCAM, Audient. My next AI will be M-Audio again!
Old 05-02-2022, 01:48 AM
pluginer pluginer is offline
which one is good from here?
Old 05-02-2022, 04:20 AM
Southsidemusic's Avatar
DT-770 Pro all day long and HD-25 plus or normal HD-25 MK2 another given.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 05-03-2022, 06:29 AM
To Pluginer; you should have started your own thread about headphones.
To Maris; Avid's choice to partner with M-Audio was more likely about dollars than quality. Having owned and used several items from both manufacturers, I still stand by my comment(sorry)
Fast Track c400 headphone stereo question thesh FireWire & USB Audio Interfaces (Win) 2 09-25-2015 04:19 PM
Output distorting once I plug in M-Audio Track Plus mhills649 Pro Tools M-Powered (Win) 0 11-23-2014 09:34 AM
C400 Headphone Volume Control Cracking Hissing Bitlo FireWire & USB Audio Interfaces (Mac) 0 04-17-2013 07:34 AM
C400 headphone control TheBoss2012 Pro Tools SE and Essential (Mac) 0 11-21-2012 03:06 PM
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs MR290378 Eleven Rack 12 11-29-2011 05:10 PM
