Old 06-03-2010, 11:37 AM
jc335 jc335 is offline
Default S/PDIF Output w/003
When I route my session output to S/PDIF (RCA) my output(monitor) control on my 003 does not work. My documents indicate the S/PDIF output channels always mirror main outs 1 & 2., therefore, I should be able to control volume from my 003... any ideas
Thanks
MacPro 2.66 Quad OX 10.4.10 - Digi 03 Factory - PTLE 7.4 cs2
Old 06-03-2010, 11:47 AM
daeron80 daeron80 is offline
Default Re: S/PDIF Output w/003
No, the monitor control does not affect the level on any digital buss.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 06-03-2010, 11:53 AM
cwsand's Avatar
cwsand cwsand is offline
Thanks
Yep, that was a disappointment when I got my 003 that I had no control over the volume to my digial monitors using the S/PDIF out, and there doesn't seem to be any kind of affodable digital master volume control available.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 06-03-2010, 12:20 PM
Think about it. If the monitor knob controlled the level of your stereo mix bus, when you turned it down, your mix would be quieter and lower res. You'd be forced to listen to all your mixes at full volume to get proper mix down level. That would make PT pretty much unusable.
David J. Finnamore
netnoggin netnoggin is offline
Add a master fader in the project? Ooops, never mind, just reread your post.
NN, aka Hobonoggin
H.I.T. Program graduate (Hobo Internship Training)
Old 06-03-2010, 12:27 PM
thanks - I guess I'll stop trying. So do you just control the volume via speaker output while the 003 output is cranked? Seems a little reckless.
Old 06-03-2010, 01:17 PM
cubivore cubivore is offline
i got a lavry da10 used for a good price. i know you probably don't want to spend any money, but that's about the only answer i got.
Old 06-03-2010, 03:27 PM
The Presonus Central station works fine for this(and does a lot of other cool stuff as well)
Old 06-03-2010, 06:49 PM
Yes, Central Station is a good unit if you have multiple sources to switch between, like a CD player, a Masterlink, etc. What is the S/PDIF feeding?
David J. Finnamore
Old 06-03-2010, 08:45 PM
rqstudio rqstudio is offline
The S/PDIF is typically like a 2-track output on a mixer. It IS designed to be that way. When you are doing a mix on a larger board the 2-track would obviously go to your mastering machine, so you can make adjustments on the board a constant signal gets recorded. Although we can do all of that on a $5 mouse, the concept remains the same.
www.rickqueststudio.com
No output from S/PDIF on 002 Rack George Siede 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-27-2013 10:06 PM
S/PDIF Output Does Not Appear in I/O Options akakpaws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-02-2007 09:53 PM
S/PDIF Output for tracking??? avamark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 03-14-2007 06:15 PM
002 R S/PDIF Output not working tabnetic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-21-2007 09:35 AM
888 interface's s/pdif input doesn't like AMIII s/pdif output jmark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-19-2001 01:03 PM
