Dual Boot XP
I want to make a dual boot system for xp pro. 1 boot for internet and 1 boot for PTLE.
Do I have to get two separate auth codes from Microsoft? Also can I format both partitions to NTFS? I want to put xp pro sp2 on both partitions.
I wear the pants. (My wife picks them out) |
Re: Dual Boot XP
No you don't need a separate auth code from M.S. and Yes both partions can and should be NTFS.
FatBelly Slim Oh no, not the sprinklers again. |
Re: Dual Boot XP
Re: Dual Boot XP
according to microsoft, you need two copies of XP.
http://soundofthatday.com |
Re: Dual Boot XP
Thanks for the help guys. I got my 2 os up and running. FYI you do need two separate auth codes if your going to do this. After a couple of calls to MS I got my system up and running. No more internet on my PTLE system!
Re: Dual Boot XP
I have seen it done without two codes, same os disk connect to the net to authorise and then never use the internet connection again.
Neil.
MBOX MINI PTLE 8.0.3 MAC OSX Snow Leopard Mac Mini 1.5Ghz Intel 2 Gig RAM ******************* |
Re: Dual Boot XP
I think that it is bull that you need two seperate codes. What, are you going to run them both at the same time?
OT: PT-Win 7 / XP Dual-Boot; Question re: Win 7 Install, Boot Manager Files | taylor4814 | Windows | 1 | 02-16-2012 05:54 PM |
Boot Camp - Dual Boot, Dual Versions of PT LE? | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-17-2009 04:15 AM |
dual boot on a g4 | keysmia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-06-2005 11:19 AM |
Help with Dual Boot on Dual 1 ghz QuickSilver | new engineer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-13-2005 06:12 AM |
Configure Dual Boot on New dual 1.25?? | cliepe12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-10-2003 04:45 AM |
