Old 10-14-2016, 08:40 AM
kbillones kbillones is offline
Default Re: Help!! PT 12.5 running slow while other sessions are ok!
Originally Posted by firmflange View Post
Hi Chief, When I isolated the clips to just show "Auto-Created", no clips showed up.
Cwsand: I deleted all those files that they suggested from that link. Still no difference.
I disabled all the plugins like kbillons said and it seemed to run a little faster, but no where near the speed of the other sessions.
what is your playback engine setup? are you editing MIDI tracks?or all audio tracks?
Old 10-14-2016, 09:07 AM
firmflange's Avatar
firmflange firmflange is offline
Hi kbillones, The strange thing is is that nothing has changed on my play back engine between the session and any other session. I am only using audio tracks right now with some plug-ins.
Old 10-14-2016, 09:15 AM
jeam25's Avatar
jeam25 jeam25 is offline
Hi firmflange !
Hi is your audio region screen box on the right side ? Do you have too many audio files there ? If so , you can try editing your files , consolidating and deleting unused files . Try that !
Hope this helps !
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 10-14-2016, 09:16 AM
Hi kbillones,
I tried tried copying the folder, no success. I'll probably do what you suggested as a last resort. I would have to redo all my effects parameters though, which is why I'm trying other things, unless anyone has a different thought.
If I trash all the preferences, will I lose all the settings on my 'Artist Control'?
hey firmflange. I'm not sure on what you exactly did here,did you just copy the folder in your local drive?or import all the session data to a new session? I actually did experienced the same thing you are experiencing right now and what I did was to "save in" copy of my problematic session and then create a new session then import all those session data to the new session created.
ref. video https://www.youtube.com/watch?v=gv1ruzgV_mw
Old 10-15-2016, 11:31 AM
firmflange's Avatar
Somehow files from other sessions landed in the Clips column (or is that supposed to be like that?). I just want to understand this right :)
When I select the unused files - even files that I see that are from other sessions, does the 'REMOVE' option delete them from my other session? Does "MOVE TO TRASH" delete them from this and the other session?
  #16
Old 10-24-2016, 04:35 PM
Post Re: Help!! PT 12.5 running slow while other sessions are ok!
No, the 'REMOVE' option does not delete them from your other session. It only 'REMOVES' them from the current session.
It moves them to the trash, which means that your other session will not be able to find them. Technically, the reference is still in the other session. Practically, if you empty the trash, it is deleted from your other session since your other session will not be able to find it.
  #17
Old 11-08-2016, 02:40 PM
firmflange's Avatar
I removed the files and it still is bogging down. A strange thing I noticed happening is that whenever i highlight a single file, all files get highlighted. It's almost like a button is held in, but it's not.
I tried copying the session, same problem occurs.
  #18
Old 11-09-2016, 01:33 PM
Question Re: Help!! PT 12.5 running slow while other sessions are ok!
Do you have the all group enabled? If you select a file in on the timeline, is that the only file selected in the clip list?
  #19
Old 11-09-2016, 02:40 PM
firmflange's Avatar
Ya you're right, Chief, the all group was enabled, but it's still is very very slow. Could it be a corrupt session?
  #20
Old 11-14-2016, 08:02 AM
Arrow Re: Help!! PT 12.5 running slow while other sessions are ok!
Possibly. The only way to prove or refute this would be to create a fresh session and import tracks one by one until you either reproduce the problem or have imported all of the tracks.
Slow startup / Slow opening sessions MrSoliman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-21-2018 12:45 AM
Previous sessions running very slow after upgrade Upere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-09-2011 04:59 PM
Sessions running slow even after ram upgrade... rc86mike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-17-2006 07:29 PM
Anybody else have slow running sessions? Stevie D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-15-2004 08:33 PM
XP running slow Old Skratch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-21-2002 05:33 PM
