Old 03-31-2014, 07:42 AM
chabarax chabarax is offline
Default Master fader question
Is there a way to for example use reverb on all tracks BUT 1 track using the master fader? Or do you have to use a bus and send all tracks individually?
Thanks
/Fabian
Old 03-31-2014, 09:13 AM
Default Re: Master fader question
Bus and send is(and has always been) the preferred method for adding delay and reverb effects.
Old 04-04-2014, 07:43 AM
Ben Jenssen's Avatar
Originally Posted by 68Tele View Post
You could simply create a stereo buss using aux input. You could label it "pre-master" or "submaster" or "verb buss". Just insert a verb on it and route all your tracks "BUT 1" to that new buss.
Then send the 1 track you don't want reverb on to the Master Fader.
Not saying this is the best way, it's just an easy option.
That's what I would do.
I think it's the best way.
I actually always route everything via a "sub master" so things like this can be fixed in a flash. It has several advantages for my workflow.
In case you didn't know:
If you select all the tracks you want to go to the "submaster", by clicking and highlighting the track names, you can press and hold "option" and "shift" (mac) as you change the output of one of them, and the change will be applied to all selected. Same would happen with inputs, inserts, sends and so on.
[IMG] code is Off
Master Fader question saltydeath 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-17-2011 07:52 AM
Basic Gain Structure Fader/Master Fader Question acmost Pro Tools TDM Systems (Mac) 1 05-16-2011 05:36 AM
Master Fader Question MaKoRancid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-12-2006 07:07 AM
Master Fader Question HR123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-23-2003 01:15 AM
Master fader question??? Tom Harmon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-09-2002 08:10 AM
