Old 12-13-2021, 11:28 AM
DDhayes DDhayes is offline
Default True Z repair
The true Z input on my eleven rack is loose or bad. Trying to find parts to repair it.
Old 12-13-2021, 11:52 AM
Default Re: True Z repair
What's loose the socket itself or the plug in the socket? Intermittent electrical contact? (if so see if the contacts inside are bent or broken if bent can you bend them back). Retainer nut is there and tight?
Basic electronics stuff: if it's an intermittent contact also reflow the solder to check for a dry joint.
If you need to replace the 1/4" socket you should be able to get a part number off it, or even without, and find a part on Digikey or Mouser.
I can't recall for sure but if you are in a pinch I suspect you can swap the Output to Amp 1 socket with the Guitar In socket.
HD I/O repair? efisch Pro Tools HDX & HD Native Systems (Mac) 4 01-14-2017 09:44 AM
003 Repair Pierres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-23-2011 04:50 AM
AKG 414 repair F.J. General Discussion 3 10-24-2005 11:54 AM
help with pop repair willbgoode Pro Tools TDM Systems (Mac) 4 11-18-2004 08:39 PM
mic repair in NYC? wolfhound Pro Tools TDM Systems (Mac) 4 08-08-2002 04:09 PM
