Old 05-02-2009, 10:17 AM
porkipine porkipine is offline
Default Window buttons don't close the window
The Mix and Edit window button switches only open and make active. Once I select the mix window and it opens, I can't close it by toggling the button. The plug-in button however, does open and close the plug-in.
Command 8
PT ver 7.4.2
Shortcut for close plugin window José Luis Díaz Tips & Tricks 11 02-02-2018 08:06 AM
pop up window buttons do not function Robocop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-21-2005 11:23 AM
No buttons on transport window!!! dooni Digidesign Hardware & Software 2 05-29-2001 08:23 PM
No buttons on transport window!!! dooni Digidesign Hardware & Software 1 03-30-2001 10:48 PM
Can't Close Preferences Window DavidMPierce Digidesign Hardware & Software 8 11-13-2000 08:23 PM
