Old 02-14-2024, 10:32 PM
RedMagpie RedMagpie is offline
Default Can't drag multiple tracks from clip bin
Hi all, for some reason PT is not allowing me to drag multiple clips from the clip bin(?) on the right hand side of the Edit window into the empty tracks.
I used to highlight all the tracks in the clip bin and then simply click on one track and drag all the clips across. Now, I highlight all the tracks but I can only drag one track across. Thanks in advance
Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz 3.60 GHz
Windows 10 Pro
Pro Tools 12
Fireface UCX
Old 02-15-2024, 12:43 AM
noiseboyuk noiseboyuk is online now
Default Re: Can't drag multiple tracks from clip bin
Probably linked to this bug - https://duc.avid.com/showthread.php?t=426506 - but might be worth contacting support just in case. The linked bug should be fixed in the next release.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 02-15-2024, 06:50 AM
cvicente22's Avatar
cvicente22 cvicente22 is offline
Hi RedMagpie,
I saw your case 04757983 and associated it to the existing bug PT-313812.
Regards,
Charles
________________
To create an Avid Support Case, you may go to https://www.avid.com/learn-and-support/contact-audio-and-music-support
Old 04-17-2024, 04:50 PM
The problem I have is still not fixed. Still can only drag one clip at a time rather than multiple clips at once. It's really annoying because I have to drag each clip separately, and if I have a song with 45 clips that is really annoying.
Please Pro Tools fix this bug!!!
Windows 10 Pro
Pro Tools 12
Fireface UCX
Old 04-18-2024, 06:27 AM
cvicente22's Avatar
Hi RedMagpie,
May I ask what version of Pro Tools are you using? I checked the bug created for this, it has been resolved since 2024.3.
Regards,
Charles
________________
Old 04-18-2024, 07:02 AM
its2loud its2loud is offline
In your original post you mentioned Clips Bin but then said you’re dragging tracks. Are you dragging clips or tracks?
If clips then check your drop order. Is it Top to Bottom or Left to Right?
clip-gain for multiple tracks blue-element Getting Started 2 11-28-2021 08:32 AM
Clip List - Multiple Clip Drag & Drop in 2020.3 TerryBarnett Pro Tools 2020 2 04-04-2020 03:14 AM
Can't 'Drag across multiple tracks' mrhappy1997 Pro Tools TDM Systems (Mac) 1 11-11-2015 04:49 PM
clip gain on multiple tracks at once? gamblor Pro Tools 10 8 06-17-2013 10:20 AM
Track hide/show window...drag multiple tracks JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-01-2004 12:53 PM
