Old 04-05-2018, 07:33 AM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
Default Mcdsp
I've been doing native work for the last 2 years after being in TDM land for 15 ish years. I currently use Slate VMR as my main channel strips for tracking low latency tracking.
I've been thinking of going HDX again. I have some McDSP plugins but not a ton. Downloaded the bundles and they seem ok for general tools. Anyone using them as their bread and butter in DSP land?
I have more than enough plugins. But I'd like some DSP capable plugins that rock if I go that way for future proofing.
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
I'm either working, sick, or both.
Old 04-05-2018, 09:22 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Mcdsp
Almost all of Plugin Alliance is AAXDSP
I use very few McDSP
Daniel
Old 04-05-2018, 09:31 AM
Stig Eliassen's Avatar
Default Re: Mcdsp
I use Filterbank, AE400 and Futzbox in nearly every session. All AAX-DSP. Softube FET is my go-to for compression, and I just started using bx_opto.
Old 04-05-2018, 12:18 PM
audioluche audioluche is offline
Default Re: Mcdsp
I've used AE400 and 600 a lot but Sonnox dyn eq is now AAX DSP and i like it better. But McDSP dynamic eq is quite good. I've used 6030 compressor, but i use Arousor, softube tl100 and bx opto most of the time for compression. I think McDSP has great plugins but for bread and butter AAX DSP plugs, dont forget to check plugin alliance, sonnox and softube.
Old 04-05-2018, 04:05 PM
Default Re: Mcdsp
Are you guys finding that you're using the native counterparts more once you're in mix mode? As an example, clients will send me routinely 70-80 tracks per song to start. Judging by mcdsp literature, if I just used one of their 6050 strips on each track, that would take up the entire card.
I can probably load 120 of em natively and my HDN wouldn't move past 20%. But I'd love it on my hdx bass tracking channel if I went Dsp.
I'm coming from having at one point hd5.
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
Old 04-05-2018, 05:21 PM
BScout BScout is offline
Default Re: Mcdsp
You get 4 instances of 6050 per chip. For one HDX card, that's 64 instances over 16 chips with 2 additional chips devoted to the mixer. So if the mixer wasn't needed (which it is) you could get 72 instances max.
Old 04-05-2018, 05:37 PM
Default Re: Mcdsp
thanks for that pic. For me, I'd basically really want DSP for a few select instances. I've been doing bands just fine with Native. But personally, doing some Hammond and Bass work, where that instrument click is so important to lock in, I am shooting for anything I can latency wise. My system has been a little squirrely lately. Thanks again for the info!
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
HTML code is On
FS: McDSP 6030 HD v5 & FutzBox Native v5 (for sale with permit from McDSP) Dusty Angel Buy & Sell 3 11-15-2013 07:00 AM
mcdsp AC1 akaidai General Discussion 2 12-05-2009 08:59 AM
McDSP anybody? sykobilly65 Pro Tools M-Powered (Win) 5 08-14-2006 08:22 AM
DUY 's vs. McDsp's GORILLA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 01-15-2003 05:04 PM
McDSP goes HD AE Pro Tools TDM Systems (Mac) 2 04-05-2002 10:05 PM
