Re: Protools 11 boots, but hangs on opening a session.
Yes - you may well have been lucky with your setup before but as they say in the financial world: past performance is no indicator of future performance. |
How many times do I have to post this I'M NOT RECORDING TO MY INTERNAL DRIVE
You're mixing up things. There is world between maximum performance en total crash on trying to open any session. I've been working with Protools for more than a decade I know exactly when Protools is on max performance. That generates completely different errors and glitches than what I've experienced last week. And as mentions in my first post I solved the problem I only had to do something unusual, that's what I wanted to share. Everything is working fine again. Cheers Hugo
Kind regards Hugo Protools 11 iMac late 2012 3.4 GHz i7 16GB Ram 3TB Fusion Drive Mavericks 10.9.3 Metric Halo ULN2 Expanded - connected with thunderbolt to FW800 adapter to cable FW800/FW400 |
What I've also been trying to say is you may be having problems with your internal drive (or the file system on it) and have outlined the steps to check if that is the problem. That business about booting from an external drive and then the internal drive seeming to work can be pointing to that kind of problem. There are some problems that can be fixed just that way. There are also some problems that can be fixed by booting into safe mode on a Mac and then rebooting into normal mode. Please try these things and see what happens. You shouldn't be having these types of problems on a regular basis and if it were a PT 11 problem there would be more complaints on it. When PT crashes - are you sending in the report to Avid? Sometimes when PT crashes a report is generated that you can send in. |
Opening Session Hangs on Restoring Tracks.... | dts.music | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-29-2009 12:49 AM |
PT 7.4 cs5 OSx 10.4.11 Protools hangs on session close | xxicjoy | Pro Tools TDM Systems (Mac) | 1 | 02-25-2009 01:08 PM |
Opening Session Hangs/Freezes System | ptal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-29-2006 01:34 PM |
PT 7 Hangs while opening a session | Baseman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-24-2006 05:15 AM |
PTLE on XP hangs opening a session | paganini12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-22-2002 12:10 AM |
