Old 03-01-2012, 05:26 AM
Toto2004 Toto2004 is offline
Default Digitest failure
A HD Accel PCIe card failed digitest. I run Protools HD10 (HD2 rig) under Lion with a 192.
Reinstalled the cards but the card still fails.
Any ideas what the error below mean?
DSP External S-RAM Test (X Memory ) DSP B: Failed
-Host port read error occurred.
DSP External S-RAM Test (Y Memory ) DSP B: Failed
DSP External S-RAM Test (P Memory ) DSP B: Failed
Old 03-01-2012, 10:04 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Digitest failure
Originally Posted by Toto2004 View Post
Chip number 2 has got faulty ram! some plugins will go a bit crazy if they instantiate on that chip. some plugs will still work ok, but any that use ram will probably emit a clicking or popping sound.
If you find a plugin is creating such noises! check if it is on the number 2 chip, if it is then deactivate the plugin then click on the number 2 chip to disable it, it will read allocated, then re-activate the plugin.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-22-2014, 01:16 AM
the dude's Avatar
the dude the dude is offline
FYI the RAM on the cards is not used like the RAM in the computer
its dedicated to the DSP chip ( in your case B )
There is Internal DSP RAM and External DSP RAM for each of the DSP and SSP chips
It has nothing to do what so ever if any plugin uses RAM or not, the attached RAM Chip is used for computation of the algorithms used by the DSP/SSP Chip
Bad ram especially either A or B will cause strange bussing issues and erroneous signals in the software
only the RAM in the CPU slots ( sticks ) are used for plugins that require RAM
I have all the parts and SMD stations to repair the cards if interested
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 05-03-2014, 11:36 AM
LSD-Studio LSD-Studio is offline
damn, so the PCIe core card in my B-rig seems to have a faulty RAM as well.
does anyone know if there's someone in Europe who can fix those cards?
DigiTest failure? UCB_Theater Digidesign Hardware & Software 2 12-12-2006 06:13 PM
Digitest failure rubberlugs Pro Tools TDM Systems (Mac) 3 02-18-2005 05:15 AM
digitest failure jackruston Pro Tools TDM Systems (Mac) 23 08-10-2002 12:59 AM
Digitest failure gitarrcarl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-18-2001 05:51 AM
Digitest failure Redsandblu Pro Tools TDM Systems (Mac) 0 12-11-2000 04:29 AM
