db25 PC pinout
I am trying to get an analog output from my 192 to a PC Main Unit (input 2) via a DB25 cable. I know that the 192 is outputting since I have hooked the ana-outs directly to my monitors and can hear program (via a db25 to xlr cable) but when I try to run it through the PC via the db25 in order to get some monitor control, no audio seems to pass through. I am wondering if the db25 cable is wired in a way that is not compatible with the PC. Anyone have any ideas ? Thanks for any and all help ! Grant |
Re: db25 PC pinout
For some reason when you want to hear output 1-2 from 192io and from software you should conect 7-8 cable jacks to controll room monitors.
I dont know why buy thats mayby a problem. |
Re: db25 PC pinout
thanks koka, but my connection is db25m to db25m, so while you are right I am trying to understand if the pinout is mapped the same way or if anyone else has run into his problemo.
Re: db25 PC pinout
there was a pinout problem on the pc do a search you will find the info
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
FOH link Pinout? | C Hawk | VENUE Live Sound Systems | 3 | 06-06-2010 04:54 AM |
pinout config. | blue demon | ProControl, Control|24, Command|8 | 1 | 02-24-2004 09:01 PM |
Anyone know if a Tascam CU/SD105 db25 to db25 will do the job? | juniperjuniper | Pro Tools TDM Systems (Mac) | 2 | 05-22-2002 12:30 AM |
DB25 to DB25 snake | Viditte | ProControl, Control|24, Command|8 | 5 | 03-26-2002 03:03 PM |
MachineControl Sony pinout 9-pin | Busshart | Tips & Tricks | 0 | 09-19-2000 01:57 AM |
