Old 03-05-2008, 03:45 AM
req06 req06 is offline
Default Is UAD workable in PTLE?
Hi Guys,
Its been a while since I've posted here, but now I have a query which you may be able to help me with.
At the moment I do a lot of mixing with my Dual G5 and I get by fine with that, but at anothe studio the other day I used some of UAD plugins like the EMT and 1176 and the quality and depth was palpable.
Now I know UA state that their cards can be used in PTLE with a vst-rtas wrapper, but really I wnat to know how workable it is with regards to Delay Compensation.
I envisage doing most of my mixing as I am at the moment using a mixture of MCDSP, URS and Sonnox plugs but with a few choice UAD plugs such as the EMT plate and the NEVE 33609+EQ's here and there.
Could someone who has a UAD card and PTLE please fill me in on the day to daay working s of using a UAD card and PTLE nad the PDC workarounds involved?
Also how powerful is one card?
Thnaks to one and all!
G5 dp 2.0Ghz, 2.5 gb RAM/ G4 Powerbook 15" 1.33mhz, 2gb RAM/ 002r/Lacie D2 FW800/PTLE 7.4
Old 03-05-2008, 06:57 AM
BradLyons BradLyons is offline
Default Re: Is UAD workable in PTLE?
I do like the UAD1 card and highly recommend it, but I will warn you that with ProTools systems---it's hit and miss. For some it works fine while others, disaster. I firmly believe it's because you're using a VST to RTAS wrapper, I am not a fan of wrappers. If it's not a true RTAS driver, it's not truly RTAS. With that said, the UAD1 is really only going to give you a single instance of the NEVE EQ from what I understand. Have you possibly considered the Waves Vintage collection? It's quite awesome!
Thank you,
Brad Lyons
www.howavl.com
Old 03-05-2008, 11:07 AM
Hi Brad,
Thanks for the advice. This is what I thought. I was just reading the latest issue of tapeop and in that review they are using the UAD Expander with an le mbox rig and it works well.
It's not a massive priority for me but If I manage to find a cheap card from someone I will probably pick it up. If i doesn't work well I could sell it on.
Old 03-05-2008, 11:45 AM
For EQ and Compression, I'd really give the Focusrite Liquid Mix a serious consideration......HOWEVER, it needs it's own firewire bus.
Thank you,
Brad Lyons
www.howavl.com
Old 03-07-2008, 05:33 AM
I have thought of that, and I must say the blindfold test on their website is a real eye opener. I'm not in a major rush but hte one thing UAD offers is stuff like the BOSS and EMT effects. Its quite tempting as I should be ablet to take a large weight off my cpu by using the UAD for time based effects which seem to eat up alot of my g5's power.
workable quicktime versions in Tiger 10.4.9 xxicjoy Pro Tools TDM Systems (Mac) 1 08-11-2008 09:19 AM
is this a workable setup??? Gilley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-25-2006 10:36 PM
Pro tools 6.4 with OSX tiger, is this workable? sukks2bu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-31-2006 09:57 AM
Cheapest workable Mac for 002 until G5 3.0 arrives bassface 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-03-2003 09:51 AM
are they workable on Macs & PCs? taycw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-20-2001 02:09 AM
