MIDI Sync issue
I'm trying to get PT to sync tempo with my Yamaha Motif keyboard. I've set the Motif to MIDI for MIDI sync, which means it should recieve MIDI clock data from an external source, such as a DAW, like PT. What I can't figure out is how I'm supposed to configure PT to send out the data. I tried to set the MIDI beat clock to the Motif, nothing. I didn't do anything with the MTC settings.
How do I get PT to send a simple MIDI clock out to the MOTIF so I can sync up arps and so forth? I'm clearly overlooking something really simple. But, what , I don't know.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Re: MIDI Sync issue
Setup->MIDI-> MIDI Beat Clock. Check "Enable MIDI beat clock for" and check the port you want. That should be all you have to do.
Below Zero Beats on 92.7 FM San Francisco Sundays 8pm - Midnight http://belowzerobeats.com |
Re: MIDI Sync issue
That's what I thought, but it doesn't work as advertised. My Motif acts as if there's no MIDI beat clock there at all, even though I set its MIDI sync to MIDI, which means it receives MIDI clock from an external source, like PT. I'm really stymied as to what the deal is.
Re: MIDI Sync issue
How is the motif connected?
Re: MIDI Sync issue
What interface are you using to connect the synth? Does it have data lights?
Re: MIDI Sync issue
I'm using the USB MIDI connection. The MOTIF does fine as controller for, say, Xpand. I can record MIDI data to a PT MIDI track, or audio from the MOTIF if I want. So, I don't think my interface is the issue. And I'm pretty sure my settings for the Motif are correct with respect to receiving (rather than sending) MIDI clock data. So I'm stumped at this point.
Re: MIDI Sync issue
If you have an interface around try sending via that to the MIDI in.
Re: MIDI Sync issue
I'm not sure what you mean by an interface. And do you mean the MIDI in of PT or the MOTIF?
Re: MIDI Sync issue
Well, I'm still nowhere on this one. I also set up a MIDI track and selected the Motif as the input source. I can play all my soft synth plug-ins off the motif, and the controllers (pb, mod wheel, etc) all work just fine that way. And if I play a midi sequence, it will play on the motif just fine. BUT, I can't get the clock in PT to sync with the MOTIF so I can sync up arps, for example. I'd like to sync an arp off XPAND with one off the Motif and that is not happening, and I can't understand why. What is the equivalent command on PT that says "send the midi clock timing out to this module" ? I thought it would be the midi beat clock set-up, which I set to go to the Motif. But that doesn't seem to do the trick. What other step is there? I can't find it in the manual, or I'm not looking at the right instruction or something.
Can someone point me in the right direction? Or, maybe the otherway, where the Motif clock out controls the tempo in PT. At this point, I'd take either one. Its frustrating. I just know its something really simple, but for the life of me can't figure out what.
Re: MIDI Sync issue
Has anyone tried sycning up a Motif XS with PT? Surely I'm not the only person on the planet whose tried to do this.
Pt10 midi instruments sync issue with audio | digi003 | Pro Tools 10 | 19 | 12-28-2013 08:23 AM |
Sync issue, pro tools MIDI and MIDI controller, timing issue | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-29-2011 07:57 AM |
Midi Timing Delay Sync Issue: MTC Sync | daysean | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 01-22-2007 11:48 AM |
Upgrade to PT 5 software? MIDI Sync issue | digiman57 | Pro Tools TDM Systems (Mac) | 1 | 10-28-2002 07:00 AM |
Sync Processor's Tremolo to Midi Time Sync via Interface | j_jayzatuc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-01-2000 12:08 AM |
