Old 01-19-2007, 09:41 PM
tabnetic tabnetic is offline
Default 002 R S/PDIF Output not working
I'm not sure why, but I can't get my 002 to output signal from the S/PDIF. I just got a monitor controller and I want to send a digital signal to it and have the controller do the D to A, but there's no signal. i know it's not the controller b/c my 828mkII can send s/pdif fine. is there a configuration i'm missing, or is my 002 just broken?
i went in i/o setup and checked everything i knew how but no luck. however, i can use the s/pdif IN to sync external clock, so is it possible the input is fine and the output is burned?
please help if you can. thanks
Tab
_______________
003R PTLE 8
Mac Pro "Nehalem" OS 10.6.5
Axiom 49
NI Komplete
Old 01-20-2007, 05:07 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: 002 R S/PDIF Output not working
What are you sending to the S/PDIF output? Master fader?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-20-2007, 09:43 PM
yes, i was sending the master fader to the A12/s/pdif1-2 out that is the default then i alternately tried to create another s/pdif output in the i/o menu when that wouldn't work. any thoughts?
nevermind, i figured it out that it was a limitation in the digi002 that i did not know about.
here is the solution if anyone has the same problem
http://www.digidesign.com/index.cfm?...0&itemid=17480
_______________
003R PTLE 8
Axiom 49
NI Komplete
Old 01-21-2007, 09:35 AM
Thanks. I came from a 001 and didn't know you had to set mirroring with the 002. Good to know.
Park
S/PDIF Output w/003 jc335 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-03-2010 08:45 PM
mbox2 pro s/pdif output ronknights 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-28-2009 05:19 PM
S/PDIF output and inserts quit working crom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-30-2003 08:59 AM
888 interface's s/pdif input doesn't like AMIII s/pdif output jmark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-19-2001 01:03 PM
Monitor Mode not working with S/PDIF output MichaelK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-24-2000 03:34 PM
