Wavefile Syncronization
Hello,
My question is how to sync up two wave files. In my old DAW, I would line up the cursor on the leading edge of, say, a drum event, and then simply grab the second file and line it up to the cursor. This worked fine and the two files were always correctly in sync. When I try this in PT however, (Slip Mode) clicking on the second file causes the cursor to disappear, so I no longer have that visual reference. My question is how to sync up files to each other in the editing window? Thank You |
Re: Wavefile Syncronization
Use "Spot" mode.
Hello, spk and thanks for the tip. After goofing around a bit, I found out that you can set sync points even in the slip mode. This way I can simply grab the wave and pull or push it into place without having to use the Spot menu - which I can't understand anyway.
insert your cursor at the beginning of the event you want to MOVE. hit ctrl+ COMMA. this will insert a sync point.
Now, place your cursor at the beginning of the event you want to sync it to. I believe the hot key is WIN+SHIFT+CLICK on the region you want to MOVE (with the grabber tool) and it will snap the sync point to the cursor. (if not then it is alt+shift+click) Or you could create a sync point on the other region and just zoom in and line it up visually. Hope that helps, happy new year.
Joe Fitz Producer / Engineer |
Video lagging when scrubbing on wavefile. | fakeknot | Post - Surround - Video | 1 | 04-06-2011 05:13 AM |
Syncronization Question | loginame | Pro Tools M-Powered (Win) | 0 | 03-07-2007 04:12 AM |
Wavefile slicing | SlipKid | Pro Tools M-Powered (Win) | 3 | 12-31-2006 11:18 PM |
losing wavefile display | oreo1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-14-2001 07:06 PM |
Syncronization / SMPTE/EBU - Help! | AcornSound | General Discussion | 0 | 03-15-2000 01:53 PM |
