Old 01-24-2006, 05:15 AM
Baseman Baseman is offline
Default PT 7 Hangs while opening a session
I have a problem with opening sessions as described below.
When I open a session made in PT 7 LE PT frequently hangs with message “activating inserts” or ”restoring tracks” But when I open an earlier backup, it opens normally. When I close that session and I open the other one. it also opens normally. Very strange I think. With PT 6.9 i never had this problem.
The G5 I use is a clean install and PT 7 also.
The session is still at it’s original location where I created it. I also tried to copy the session to my system disk but it didn’t help. Disk Utility didn’t find errors on my disks. Maybe some of you have an answer for my problem.
Thanks in advance for your help.
Best regards:
Bas Meijer.
My setup:
OSX 10.4.3
PT 7 LE cs3
Digi 002R
Dual 2.0GhZ
1500 MB
2 x160 GB
Protools 11 boots, but hangs on opening a session. Hugo.K Getting Started 12 11-10-2013 04:36 AM
Opening Session Hangs on Restoring Tracks.... dts.music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 04-29-2009 12:49 AM
Pro Tools 7.4 hangs when opening buzzedit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-07-2008 09:52 PM
Opening Session Hangs/Freezes System ptal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-29-2006 01:34 PM
PTLE on XP hangs opening a session paganini12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-22-2002 12:10 AM
