Old 10-25-2005, 06:56 PM
Blaminack Blaminack is offline
Default Inactive Plug in?
I was attempting to use Reason in ProTools... all was fine and suddenly my screen said I was running out of CPU as I was running FLS at the same time and then Reason cut out also now when I open the same file again it says that Reason has been made inactive. How do I go about turning it back on?
Thanks for your help!
Blessins
Old 10-25-2005, 11:26 PM
Default Re: Inactive Plug in?
You can toggle a plug-in enabled/disabled state by Ctrl+Start clicking on the plug-in insert.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-26-2005, 04:05 AM
I should have mentioned thst I use a PC... sorry, is there a start key some where on the PC Keyboard? Is there are comparable key for the PC? Thanks for the reply.
Old 10-26-2005, 05:21 AM
Hogie Hogie is offline
the start key is in between the Alt and Ctrl keys... with the windows logo on it.
Back to basics: Strat, DRRI, and pedals gallore.
Old 10-26-2005, 10:39 AM
The Apple keyboard doesn't have a Start key... on the Mac it's Ctrl+Command click to disable/reenable.
Rail
Platinum Samples
Old 10-26-2005, 03:35 PM
Thanks both of you! I did find the problem but the solution wasn't in ProTools even though that is where I found it... It turned out that Reason didn't completely close a file (it didn't even show up under processes in the Windows Task Manager) and I didn't see it until I tried to start Reason with ProTools off... It wouldn't open so I decided to ReBoot and when I did Windows showed that there was an open process that wasn't closing... delete32 something or other. I ReBooted... Problem solved.
Thanks again for the help!
Blessins!
Missing/Inactive Plug-ins ac30fan macOS 1 11-26-2011 11:20 PM
Inactive Plug ins ...? Laufdal Pro Tools M-Powered (Mac) 7 03-08-2010 02:16 PM
Plug Ins inactive Colbyjack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-16-2009 09:26 PM
inactive plug in fix? acacia Pro Tools TDM Systems (Mac) 2 08-26-2005 02:19 PM
DAE -2 Plug-in inactive Buzzhound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-24-2003 07:52 AM
