  #31
Old 10-28-2021, 08:16 AM
ekmaster23 ekmaster23 is offline
Default Re: Pt | 2021.10
It is not useless, but some surprises may surface
Pro Tools won’t even get past loading plugins on a new MacBook so I’d say it’s pretty useless personally. Unless you’re just editing.
  #32
Old 10-28-2021, 10:04 AM
off the wall's Avatar
https://www.avid.com/resource-center...4NPZp6GabM9Vxg
offthewallproductions
  #33
Old 10-28-2021, 10:21 AM
daeron80 daeron80 is offline
Originally Posted by off the wall View Post
"With the October 2021 release, you can now run ... the Avid Video Engine on the latest Macs that use Apple’s new M1 silicon processors."
Woohoo!
David J. Finnamore
  #34
Old 10-28-2021, 11:03 AM
glogulus2003 glogulus2003 is offline
Welp. I was hoping this would fix the random plugin stalls on load when running on Monterey but no luck. Still hangs on random plugins on startup. If I remove all plugins it starts up fine, but after installing just the avid complete plugin bundle it still hangs. Guess I will just fall back and wait for official support.
  #35
Old 10-28-2021, 11:17 AM
JingleDjango JingleDjango is offline
Like many others, I was experiencing persistent, destabalizing and frequent UI hangs on 2021.06, such that I had reverted to 2020.09.
I'll have to spend more time with it to confirm but I loaded up a busy mix session in 2021.10 and haven't seen a beachball yet.
  #36
Old 10-28-2021, 12:11 PM
Eric Lambert's Avatar
Monterey isn't yet supported.
  #37
Old 10-28-2021, 01:03 PM
epmi epmi is offline
If you go into finder and remove any plugins that say "date modified" 2018, you can at least get it working. Unfortunately, this includes removing Pro Compressor.
  #38
Yep. Took a gamble and lost. No worries though. I'm sure Avid will figure it out.
  #39
Old 10-28-2021, 01:18 PM
Thanks for the info! That really helped. It looks like it is mostly the plugins from the avid complete bundle and I found a few third party ones that I had to move as well. Suprisingly all of my plugin alliance and waves plugins loaded fine!
  #40
Old 10-28-2021, 01:19 PM
What’s the reasoning behind this? I totally believe you I’m just wondering if anyone knows why this helps?
2021.7 on OS X 11.6 Stys64 Pro Tools 11 10-06-2021 08:55 PM
2021.7 and OS 11.5.2 Pedro perez Pro Tools 10 09-11-2021 02:40 PM
2021.6 and 2021.7 restart after exit NJsound.com Pro Tools 12 08-11-2021 01:45 PM
Downgrading from 2021.6 t0 2021.3 Mac M1 Leon77 Pro Tools 2 07-21-2021 09:43 AM
