Old 04-21-2014, 11:07 AM
Lunny_Senior Lunny_Senior is offline
Default 3rd 192 not recognised, light not changing from orange to green.
Hi there.
My studio is currently running PTHD8 with 3 192 interfaces. This morning I have come in to find that the 3rd interface is not being recognised by PT and the light on the front is not changing from orange to green. The other two interfaces are working fine. Have checked all the connections on the back and everything seems to be plugged in where it should be.
Any ideas as to whats wrong? Thanks.
Old 04-21-2014, 12:11 PM
the dude's Avatar
the dude the dude is offline
Default Re: 3rd 192 not recognised, light not changing from orange to green.
I would first check to see one of the internal IO cards has failed
A 192 will work in PT as long as 2 of the 3 cards in installed in the correct slots
Slot 1 = AD
Slot 2 = DA
Slot 3 = DD
or you can have a AD or DA card installed in Slot #4
So maybe pull a ribbon cable on one card at a time till it is recognized
also does it indicate loop master on the front plate ?
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 04-21-2014, 12:15 PM
Loop master was indicated on the 1st 192, nothing was showing on the 3rd. However now it has mysteriously come back to life after being left on for about 4 hours! How strange...
Old 04-21-2014, 10:48 PM
JFreak JFreak is online now
Open it up and re-seat the card ribbon cables. It sounds to me like a loose connection somewhere. As said, two of the first three cards must be present, otherwise the box won't work.
Old 04-22-2014, 01:03 AM
the dude's Avatar
playing around with the ribbon cables is something I would do with care and finesse, one a cable has even slightly pulled or separated from the IDC connector
it can cause more problems than you think
I've had to replace many many ribbon cables for that single reason
( I have higher quality ribbon replacement cables )
าำ
[email protected]m
Old 02-07-2017, 02:58 PM
Ryan Kelly Ryan Kelly is offline
Have spent two days off and on trying to get a Blue 192 to be recognized with HDX and came across this thread. It was showing the same symptoms of not switching to Loop Master when it was the only one connected and I opened it up, reseated the loose ribbon cable on the AD card and that fixed it.
Thanks!
Old 02-07-2017, 09:45 PM
Cool :)
003 rack is not connecting. Blinking green light. no HOST 1394 light. ccgascity1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-14-2011 12:41 PM
green-orange light songman Pro Tools TDM Systems (Mac) 3 01-15-2010 05:16 AM
Mbox2 Firewire Blinking Green / Orange Lights after PT8 Upgrade Attempt...Please Help Squid Vicious 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-17-2009 03:37 AM
Power Indicator Light on MBox 2 Pro - Orange or Green? Alan Brownstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-07-2007 04:10 PM
