Old 08-16-2010, 01:58 PM
stuseattle stuseattle is offline
Default Volume Automation - Edit Window
You've all been so helpful in the past . . . hope there's a command for this one.
Working on volume levels in the edit window . . . is there a way to get the line to pop back up to zero (the same way holding the option key and hitting the fader, or send, or pan, in the mix window automatically zeroes it out) without manually having to move the line? Holding down the option key in this instance doesn't seem to do it.
Thanks again for any advice,
stu
volume automation not following edit Cryos macOS 2 07-16-2011 09:36 AM
Lighten edit window and thicken the volume automation line Sukram Pro Tools TDM Systems (Mac) 26 12-09-2009 12:18 AM
Volume slider in Edit window Nazyr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-06-2009 08:11 AM
Edit Window Automation Question Jsswtpmp182 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-28-2006 02:08 AM
Edit Volume Level of a region without automation markus44uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-12-2005 05:04 AM
