Old 05-24-2022, 07:18 AM
JoeTools1963's Avatar
JoeTools1963 JoeTools1963 is offline
Default Best method or software to process hundreds of files
Hi there
I have a large project that involves processing hundreds of files in a batch fashion.
I could do it in PT, but it will not allow me to import all of the files to a single track. If I could, I could process via Audio Suite Plugs and batch that way.
That being said, is there a script that can be written to import a batch of files to a single track (say in shuffle) so they butt up against each other?
If not, is there a software that will allow me to batch import a bunch of files, use a plugin like Vitamin and then batch export. They will all have the same settings.
Thank you in advance for your input.
Joe Tools
Re-Recording Mixer/Sound Designer
Nova Scotia Canada
OS Ventura 13.0
Pro Tools Ultimate 2022.12
Mac Studio Max 32GB Ram
OS 10.8.5
Pro Tools HD Accel Version 10.3.8
Mid 2012 Mac Pro 5,1 32GB Ram
Old 05-24-2022, 07:44 AM
ToxicGandhi ToxicGandhi is offline
Default Re: Best Process Or SoftWare
Hi, you could import them to clip list, then select them all and drop them onto a track (or onto the track list to have tracks with corresponding channel widths created automatically) while having Timeline drop order (see the clip list options) set to "Left to Right". Then you'll have them all on a same track butting on one another and you could Audiosuite them with "Clip by Clip" and "Create Individual Files" settings.
For a more elegant solution, check out either Batch Processor in RX (try using the Plug-in module to load a plugin of your choice), or Batch File/Item Converter in Reaper (where you can batch process essentially anything from SRC conversions to names to FX).
Old 05-24-2022, 07:58 AM
Originally Posted by JoeTools1963 View Post
...it will not allow me to import all of the files to a single track....
Why not? Timeline drop order.
If not, is there a software that will allow me to batch import a bunch of files, use a plugin like Vitamin and then batch export....
Izotope RX, Presonus batch converter come to mind.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 05-24-2022, 10:52 AM
Thank you both!! That worked great!! Now my question is this.
Since I do not have RX on this machine and I am using Vitamin for the processing via Audio Suite, is there a way to get PT to NOT add the Vitamin suffix on to the end of the files?
There are 688 files in this batch. The naming convention needs to be maintained for the AI module.
Thanks once again in advance!!
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
Old 05-24-2022, 03:32 PM
cablenaute's Avatar
cablenaute cablenaute is offline
Default Re: Best method or software to process hundreds of files
You could give ABetterFinderRename a try, it is perfect for batch filenames renaming.
Old 05-24-2022, 07:12 PM
Fidelis Fidelis is offline
You can batch rename the files on finder! Just select all, right clic and choose rename. Now, if you want a batch converter that does all automatically Izotope rx is a good one.
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard
Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0
Old 05-24-2022, 07:59 PM
Dizzi45Z Dizzi45Z is offline
I use and love NameChanger on Mac for renaming files. It's donationware and amazing.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 05-24-2022, 11:11 PM
LDS LDS is offline
Couldn't you just batch rename straight in the pro tools clip list after processing?
After you have batch processed your audio clips on the timeline, select unused and remove to get rid of the original from the clips bin. Then select all clips, and batch rename removing the vitamin tag, then export clips as files to your final folder destination?
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 05-25-2022, 04:23 AM
Sadly the original names are crucial to the end use. Not sure how to combat this perpetual renaming.
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
Old 05-25-2022, 06:46 AM
Thanks for all of the help everyone. Problem resolved. Had RX installed on my Older Mac Pro. Batching is a breeze.
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
Hundreds of Files ... psdrummin Pro Tools 10 1 03-21-2014 04:11 PM
Best backup method for data files? mjslakeridge Windows 16 04-03-2013 12:43 PM
Put hundreds of regions on tracks at once...?! Arno Peeters Tips & Tricks 10 06-25-2005 12:12 AM
hundreds of plug-ins : categorise ?? Simon666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-26-2004 02:46 PM
24bit files to CD24 ISO to Masterlink. Process? Kingpin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-23-2003 08:58 AM
