Old 04-29-2022, 09:09 AM
Southsidemusic's Avatar
Default A quick question about meters with eucon
Hey Friends
We have not used Eucon for a long time and now when I use eucon on a brand new ipad the meters disappears on our 4 SSL UF8 if the ipad with eucon metering is on. Is this normal and if so, what is the point of taking the meters away from the controllers?
Thanks and Stay Awesome
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-29-2022, 09:21 AM
Default Re: A quick question about meters with eucon
I believe this is a known side effect of running Eucon and HUI at the same time. I can't comment on why or how.
Scott Gatteρo
Old 04-29-2022, 09:24 AM
Aha!
Yeah the UF8’s are HUI so if that is a limitation then there’s not much we can do. And the eucon meters are better anyway, just wanted to know if there was something we done wrong :/
Thank You for the info
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 04-29-2022, 09:26 AM
Originally Posted by Southsidemusic View Post
Aha!
No worries. If you post in the EuCon section, Eddie Jones might able to give you a little more backstory or context. But I don't think there's a workaround.
Scott Gatteρo
Old 04-29-2022, 09:27 AM
Yeah i saw that i posted in 2021
Will move and thanks again.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 04-29-2022, 10:23 AM
Ben Jenssen's Avatar
Also happens on my Command 8, midi protocol. If I run Eucon with Avid Control on my ipad, I lose meters on C8. Everything else works. It's a Eucon thing.
Eucon 3.6.1 - eMix 6.1.0 - No Eucon channel meters Rpro System 5 14 08-04-2017 11:20 AM
No meters since Eucon 3.3 update Tim R. Avid S1, S3, Dock and Control App 25 11-02-2015 04:45 AM
Artist Mix has lost the meters with Eucon 3.3 maaaquemeseyo Artist Series 3 08-08-2015 07:01 AM
Eucon Command for Quick Controls on Nuendo 7 wont work. KeyplayerG Artist Series 2 07-11-2015 08:54 AM
Quick quick quick DSP farm card Question Mr335 Pro Tools TDM Systems (Mac) 1 12-06-2002 07:37 AM
