Old 07-11-2021, 04:28 PM
Armando Armando is offline
Default Digi PRE Line/DI rear input Ch 1 level drops
Hello! I experienced an issue with a level “dropping off” when instrument was plugged into rear ch 1 input(1/4” TS) so I unplugged the cable and plugged into ch 1 on the front input. Had no issues plugged into the front.
Is there a component on the inside I need to be aware of? Maybe some Deoxit in the rear socket? Has anyone experienced this behavior?
Thanks in advance!!
Armando
Old 07-12-2021, 11:53 AM
Default Re: Digi PRE Line/DI rear input Ch 1 level drops
Guessing as I don't own one of these(but I bet the manual has the real answer); maybe the rear quarter inch jacks default to line level while the front pair default to instrument level(which would be hotter)? Check the manual to see how you select line vs Instrument level.
HTML code is On
MBox 3 Pro Line Input (rear) Gain Garry R 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-23-2011 03:28 PM
002 Rack Line input low level beastie boy39 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-13-2008 11:30 AM
JAMLAB - Input Line level very weak - PT 7.3.1 cs4 JazzyJ Pro Tools M-Powered (Win) 4 01-18-2008 01:45 PM
can i run a line level into a hi z input ??? skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-17-2003 02:37 PM
Digi 001's line level inputs 3-8. Control input? dcarlson247 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-26-2001 02:04 PM
