midi problem with digi 003rack
Hola, tengo un problema simple. Cuando ruteo una secuencia midi desde PT 8 a un sintetizador Korg N364, en cierto momento de la reproducción algunas notas midis quedan sonando continuamente. Este problema me sucede con frecuencia.
Alguna idea para solucionarlo? configuracion midi...etc? mi sistema... PT8 003rack Sintetizador Korg N364 Mixer Yamaha 01v96v2 Windows XP SP3 |
Re: midi problem with digi 003rack
U puede querer mantener, para comprobar la ur ... Suena como que puede ser lo que significa u u si entiendo correctamente ...
ya'll didn't know I was bi-language hunh
My problem is....routing a sequence midi from PT 8 to Korg N364, in certain moment of the reproduction some notes midi continues sounding constant. This problem happens often. Which can be the solution to this problem? Thanks |
I'm sayin that u may wanna check ur sustain in the midi... that could be ur problem as when the loop changes/loops(if it is a loop) sometimes the notes bleed over to the next loop & the sustain holds over... so those are things u should check for...
re: digi 003Rack | 2224 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-01-2012 11:51 PM |
003rack+win7-64bit PC+digi asio driver = midi input (5pin) problem! | Slaido | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-22-2011 06:32 AM |
No MIDI Devices (003Rack + 8.0.3 or cs2) | David Sabine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-05-2011 10:21 PM |
Digi 002Rack to 003rack or 003 | shanabit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-18-2007 06:41 PM |
Santa's bringing me this new DIGI-003rack, look! | nukmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 47 | 03-20-2005 01:18 AM |
