Old 07-02-2021, 04:21 AM
shabbamanuk shabbamanuk is offline
Default The old pop/static on playback
Does anyone anywhere actually have a fix for this. I been running PT11/12 for the last three years on a 2017 Mac Pro. Still running El Capitan because it works, UAD Apollo 8p. the system has been flawless for four years. Until two weeks ago.
Every play/stop action triggers the horrendous pop/crack trough my genetics. Any thing I try recording/analogue/midi it's there. Also on older sessions. Nothing at all has changed on my system. I have done the following.
Buffer adjustment.
Disabled network cards.
fresh install of PT 11/12.3.1
Tested with only the Mac Pro and ilok with no external hardware.
DC.
High pass.
pre roll fade in.
moved to a different building with a separate power supply.
I have no junk like FB on the Mac, it's clean for work only.
I am currently talking to Avid to see if I can upgrade to 12.5-7 men though my upgrade just expired. But if anyone found a real solution to this then please share it. I don't appreciate replies asking me why I'm usual what I'm using. Thanks
Old 07-02-2021, 03:55 PM
unkJE's Avatar
unkJE unkJE is offline
Default Re: The old pop/static on playback
12.6 is a paid upgrade
12.4 saw the peak of Noise Blasts complaints on the DUC
Ask Avid for an Installer for Pro Tools 12.5.1 or Pro Tools 12.5.2 for HDX, where it appears Avid fixed the Noise Blasts – it’s the least Avid can do, to protect you and your clients from potential ear-damage
If you have a VST host (like Blue Cat’s PatchWork) – instantiate the free Ice9 Automute by Cerberus Audio on the Master
"Ice9 Automute’s soft-muting function will begin to attenuate the gain before a single sample over the threshold has passed. Instantaneous radical attenuation will occur if the threshold is exceeded by a severe and potentially dangerous amount."
https://freevstplugins.net/cerberus-...ice9-automute/
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
Last edited by unkJE; 07-02-2021 at 07:08 PM. Reason: added: ice9 for ear protection
Old 07-05-2021, 01:10 AM
Thanks for the reply. Yes I am in talks with avid about an upgrade so they should take about a year. The ice9 I should have mentioned in my done list, was of little use. I'v switched to Logic Pro x for now, and it's not to shabby.
Protools 9.0.6 'static on playback' & no PT Headphone playback vcoad Windows 1 03-14-2013 04:09 PM
Playback Problem: Overpowering Static Noise: Pro Tools can not get playback fast enou JLue Pro Tools 9 1 08-04-2011 08:59 AM
Fuzzy Static with ProTools playback and window media files playback 39lashesmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-25-2011 05:41 PM
Static "Playback" with Protools and Static "Playback" with windows files 39lashesmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-20-2011 05:57 AM
Static in playback every now and then. 39lashesmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-18-2011 06:18 PM
