Old 07-19-2021, 05:08 AM
ALSTUDIOS ALSTUDIOS is offline
Default V2021.6 issues working with Cubase
Hi
I did the installation of the latest version 2021.06 without problems.
After running within Cubase PRO 11.0.30, I noticed some performance issues in the Avid Artist Control and Mix units. Sometimes the connection got lost, sometimes the response of the Avid Artist control touch buttons were very slow. (some seconds)
--> Rolled back to the previous version. Now all fine. Waiting for an update to solve these behavour.
ALSTUDIOS REGENSDORF SWITZERLAND
[email protected]
https://sites.google.com/site/alrecordingstudio/
1pc AVID Artist Control and 1pc Euphonix MC Mix
Win11 64Bit, Cubase Pro 12.0.52
Old 07-20-2021, 07:50 AM
EddieJones's Avatar
Default Re: V2021.6 issues working with Cubase
Nothing changed in EUCON to affect this. Can you try uninstalling using the installer first, including remove all prefs, reboot and then put the latest EUCON and let me know. I'm running Nuendo on a PC which uses the same EUCON code.
Old 07-25-2021, 04:05 AM
Hi Eddie,
As a big fan of the Artist series I thank you for your response to the issue.
I did what you described in your post.
Indeed there was a far better performance as it was after the first installation. Nevertheless I still had two lost connections and from time to time a slow reaction based o the Artist Control touch screen during a three hour session with multiple applications running (incl. Cubase 11.0.30).
Of course I don't know, if this would also happen with the former version of Eucon, but I remember, that I was working for days without any issue with the former version of Eucon.
I see, that this does not really help you to recover the stability of the system, there must be somethings changed within the code, that takels the performance - at least on my system.
Because there is no improvement for my units with the newest version of Eucon, I definitely roll back to the Version 2020_11_1_10.
Anyway thank you for your reply and cheers
[email protected]
Old 07-31-2021, 06:06 AM
Hi Eddie, I have a different issue with Cubase 11.0.30 and Eucon 2021.6.0. The press and hold EQ to enter Quick Controls mode on my Artist Mix seems to be non-functioning. I did make it work once, but today I cannot despite multiple restarts. I uninstalled and then reinstalled 20_1_0_50_106701 and the functionality has returned as normal.
Thanks!
Guy Rowland
www.guyrowland.co.uk
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 09-06-2021, 12:28 AM
Eneco Eneco is offline
Thanks!
I'm having the same issue. I guess they changed the functionality of the keys and that quick controls are either gone or on a different key.
Old 09-19-2021, 01:50 AM
Thanks!
Eddie, has anyone looked into this? 2021.6.0 is no-go for Cubase users currently. Thank you.
Guy Rowland
Old 09-20-2021, 09:59 AM
EddieJones's Avatar
Can you try press and hold Aux.
Old 09-30-2021, 11:53 AM
Eddie, sorry for the delayed response - that's it! Thanks.
That news needs to be broadcast wide - for Cubase users from 2021.6, accessing Quick Controls has moved from holding EQ to holding down Aux.
Guy Rowland
Pro Tools v2021.6 Now Available Avid Technical Alerts 0 06-24-2021 09:01 AM
Pro Tools v2021.3 Now Available Kyle Splittgerber Pro Tools | Carbon 21 05-12-2021 07:27 AM
Pro Tools v2021.3.1 Now Available Avid Technical Alerts 0 04-13-2021 10:44 AM
Pro Tools v2021.3 Now Available Avid Technical Alerts 0 03-25-2021 09:16 AM
