Rendering Audiosuite FX
I could have sworn that you used to be able to render say an Audiosuite reverb or delay by making a selection longer than and including an existing clip. The render would make a new clip to the length of the selection and include the reverb or delay tail created by the plugin beyond the clip boundary.
Now I just get a clip that is as long as the original clip and the reverb tail is cut off. Anyone else see this? Has this behavior changed at some point or am I doing something wrong?
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
Re: Rendering Audiosuite FX
Working correctly for me. Mac Catalina, PT 2021.6. Tried D-Verb, Mod Delay III, and a few third party verbs and delays.
Do you have USE IN PLAYLIST selected? "Entire selection" rather than "clip by clip"?
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Thanks David.
Must be something I have set wrong then, I'll check. Good to know it still works!
It sounds like it could be Clip By Clip and Individual Files settings combined with the Handle length causing the reverb or delay tail to be included in the handle. Have you tried trimming out the end of the clip to see if the tail is there? If so, it would only be as long as the Handle setting. It would still probably be best to render these types of effects using Create Continuous File and Entire Selection settings.
Scott Gatteño |
Audiosuite not rendering? | moshuajusic | Pro Tools 2019 | 2 | 01-03-2020 11:50 AM |
Audiosuite Rendering = lost waveform | audiofreak11 | Pro Tools 12 | 2 | 09-28-2016 01:04 PM |
Fades not rendering properly in Audiosuite ? | frenchman | Pro Tools 10 | 0 | 09-06-2014 02:33 AM |
Audiosuite Rendering Problem | pmcminn | Pro Tools 11 | 2 | 05-09-2014 06:18 AM |
why is audiosuite rendering to region list and not to edit window?? | luts | macOS | 1 | 06-28-2012 12:21 AM |
