Old 01-02-2011, 07:33 AM
thisjanuary thisjanuary is offline
Default Just bought a new 27" iMac for PT9, worth upgrading RAM past 8gb?
So I just plumped down £2,500 on a shiny new 27" iMac, i7 processor, 8gb of RAM, 256gb SSD + 2TB HDD, etc.
Since I can get 4x4gb chips from Crucial to upgrade it to 16gb for another like, £160 (instead of the insane £600 Apple wanted).. should I?
I'm not sure how the RAM limits work with Macs, I know since it's not a 64-bit app, in Windows it can't use more than 3gb anyway, but £160 is nothing on top of that £2,500 and I totally don't mind spending it to double the RAM up again if it's going to give me better performance when using lots of plugins simultaneously, etc.
Thoughts? :)
Old 01-02-2011, 07:35 AM
GORILLA GORILLA is offline
Default Re: Just bought a new 27" iMac for PT9, worth upgrading RAM past 8gb?
Why? Pro Tools isn't even using all of your current 8Gigs of ram. Save your money!
METAL LABS
Old 01-02-2011, 07:41 AM
Well, that was my question. Does PT9 on a Mac have the same RAM limitations as PT9 on Windows, i.e. can it only use 3gb for the entire project, including separate plug-ins, etc?
Old 01-02-2011, 07:46 AM
And out of curiosity if anyone knows, would Logic 9 use 16gb?
Old 01-02-2011, 07:50 AM
PT 9 will use up to 4gb... I believe. Maybe someone can chime in if I'm way off!
Yes in 64-bit mode. I use it as of now, plus with it's Node app. my Wifes iMac can be used for extra CPU when using EXS's hahaha.
I really like Pro Tools, I really do. But....
METAL LABS
Old 01-02-2011, 09:42 AM
Anybody able to verify that upgrading an iMac to 16gb for Pro Tools would be useless?
Old 01-02-2011, 11:11 AM
NewdestinyX NewdestinyX is offline
Default
Useless. -- that is until PT goes 64-bit.
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard
Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS
Old 01-02-2011, 11:19 AM
Dism Dism is offline
Unless you are running software like BiDule or VE Pro.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 01-02-2011, 11:40 AM
Default
Well not really. You have to keep in mind a couple important caveats. Bidule x64 for Mac is only a beta version so far. Then both VEPro and Bidule connect with PT9 via REWIRE AND RTAS neither of which are 64bit pathways. Though I agree.. that running your VE's in x64 is an application where having more ram would be worth it. But then RTAS is still a bottleneck.
Old 01-02-2011, 12:19 PM
Oki doke. And presumably Pro Tools won't be 64-bit for several years yet, due to Avid's laziness? Yes, I said it.
iMac "Quad Core" worth it? KinetiX20fifth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 12-03-2010 11:20 AM
Hangup 8.0.3 on a Micro MBox - wont get past "Building Mix Window" Nilreb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-11-2010 12:53 PM
New 27" imac Protools 8 Won't get past Xpand Adriel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-14-2009 02:41 PM
Mac OS experts? Cant boot past flashing "?" No Internal DVD drive! fixed! crizdee Pro Tools TDM Systems (Mac) 4 01-16-2009 10:05 AM
upgrading AV past 4.1v8??? rob sayers Post - Surround - Video 3 11-28-2000 01:36 PM
