Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 05-04-2022, 07:43 AM
eightamrock eightamrock is offline
Default Reamping off of Carbon
Pardon the naive question, just hoping for some community wisdom here.
I currently use a radial passive DI to capture clean instrument signal while also micing up cabs etc.
Is there a way to output from carbon at instrument level on one of the line outputs to reamp those clean tracks without a reamp box? Im fairly sure there isnt, but just wanted to check just in case I was missing something.
Old 05-04-2022, 01:44 PM
BScout BScout is offline
Default Re: Reamping off of Carbon
The output to reamp is both level and impedance. The passive DI changes the impedance too (usually via transformer) to 10k-40k Ohm.
Though you could get the level right, there is no means to change the output impedance on the Carbon (which is 100 ohm balanced (50 ohm per leg) -- and guitars are unbalanced so 50 Ohm)
As you can see, the load difference is pretty massive if the impedance isn't adjusted.
Old 05-04-2022, 08:00 PM
yeah thats what I thought. OK thank you for the response!
Old 05-05-2022, 06:11 AM
Bennett Paster Bennett Paster is offline
You might be able to go back out through your DI backwards if you have the right cabling. I believe that should readjust the impedance properly. Or you can buy a reamping box like Radial Reamp which would do the same thing.
Late 2013 Mac Pro (trashcan), 2.7 GHz 12-Core Intel Xeon E5, 64 GB 1866 MHz DDR3 ECC, AMD FirePro D300 2048 MB, Startup disk SSD 512. OSX 10.15.7, Pro Tools 2022.10. Carbon (AVB), Lynx Aurora 16(n) (Thunderbolt)
Reamping in HD krcassid Eleven Rack 4 09-28-2010 09:21 PM
REAMPING...one more! troncomac Tips & Tricks 17 02-06-2009 08:17 AM
Reamping Jsswtpmp182 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-04-2007 12:25 PM
Anyone try REAMPING before? RBaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 06-09-2004 02:15 AM
