Old 07-12-2005, 06:09 PM
Extreme Mixing Extreme Mixing is offline
Default Keyboard commands
I know it can be done, but who knows what program will allow me to make custom keyboard commands in Pro Tools. It seems like I read that the feature is now built into OSX. Is that right?
What I would like to do is to find a way to toggle or directly select playlists with a keyboard command, rather than by using the mouse. And a <make new playlist for selected, or grouped tracks> command. Any ideas?
Steve
Steve Shepherd
Extreme Mixing
Old 07-12-2005, 07:36 PM
tball tball is offline
Default Re: Keyboard commands
You can use quickkeys or you can try making shortcuts using system prefs under keyboard, though I havent had much success. There was a thread a couple of months back covering scrolling through playlists. It seems no one has really come up with a good, easy way to do it using key command short cuts.
Mix + G4 dual 1.2 1.5 gbRAM OS10.3.8 PT 6.4.1cs3 JH-16!
Old 07-12-2005, 07:52 PM
Steve@ZooWest Steve@ZooWest is offline
Using the Apple menu, system prefs, and keyboard shortcuts, you can create a number of simple shortcuts without buying another program. It is limited, and not all sortcuts take - e.g. I can't get Hide Pro Tools to take.
However, I have a few that I really wanted - Bounce To Disk, Delete Selected Tracks, Display Name In Regions, Input Quantize, et al. They have to be entered exactly as they appear in the menus, complete with Capitals, and the "..." Note that if you trash all the prefs the way digi says to do it, you have to add them again.
You won't be able to add nested commmands.
"Modern manufactured music is like art they sell at a furniture store."
http://www.weddingmusicproject.com/
http://www.weddingmusicproject.com/w...music-samples/
http://stevemillikan.com/
Old 07-13-2005, 06:13 PM
Thanks for the info, guys. It sounds like an iffy proposal to select play lists with a key command because they are not a menu item.
Anybody know for sure?
Steve
Steve Shepherd
Extreme Mixing
Keyboard Commands Focus OddsAre macOS 1 12-13-2011 06:38 PM
keyboard commands not working. Help! grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-21-2009 01:00 PM
Keyboard Commands in OSX Ozzie Pro Tools TDM Systems (Mac) 0 10-08-2006 06:18 AM
Key commands azerty keyboard [solved] Eli V/d Vondel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-09-2006 10:48 AM
keyboard commands for ? surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-19-2001 07:12 PM
