Old 11-21-2021, 03:20 PM
Default Apple Monterey Memory Leak Traced to ...
I read this the other day and just wanted to relay it here in case it helps anybody with the memory leak issue in Monterey.
https://fossbytes.com/macos-monterey...-leak-bug-fix/
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 11-21-2021, 03:33 PM
Default Re: Apple Monterey Memory Leak Traced to Mouse Cursor
And while it may be a culprit, folks were pointing out it's clearly not the only issue. e.g. https://9to5mac.com/2021/11/15/monte...ion-suggestion
Will be great to hear if disabling the custom cursor fixes issues for Pro Tools users.
Old 01-05-2022, 01:56 PM
JFreak's Avatar
JFreak JFreak is online now
I finally found the culprit. It is the process called SafariBookmarksSyncAgent which respawns after force quit and seems to appear even if you do not have Safari syncing to iCloud enabled.
Workaround: boot your computer before opening PT session and keep your Activity Monitor open. When it starts to eat memory, force quit it and it stays calm for a while.
Today my tests showed that in 10 hours that process had read 10 gigabytes of bookmarks and written 20 gigabytes of the same stuff. Go figure. Bookmarks file is kilobytes. So it is doing read/write all the time.
This is a workaround and not a final solution, mind you. I am trying to find out what else gets broken if that thing is permanently disabled from UNIX side of things.
Darryl, are you interested already?
Janne
Old 01-05-2022, 04:14 PM
Always interested. Especially in trying to understand Finnish humor.
Does bring back memories of past pathological behavior with mdworker indexing drives. I've had to disable indexing/kill those processes because of them thrashing. Maybe Apple could be doing a better job here of detecting aberrant service processes. Do you see any helpful warning in the Console logs?
Old 01-05-2022, 09:17 PM
JFreak's Avatar
So far nothing useful in system.log but I am keeping an eye on it. The process has staid <10MB now, but once it starts leaking there should be something.
Janne
Memory leak going 11.01>10.3.6 DetroitT Pro Tools 11 0 07-18-2013 03:42 AM
Memory leak in EuControl 2.5.7 DhyanMikael Artist Series 0 04-23-2011 06:13 AM
Memory Leak in 7.3? BlindDog Pro Tools M-Powered (Win) 2 01-15-2007 08:21 PM
Memory leak in PT7cs3? UnkleMik Pro Tools TDM Systems (Win) 1 02-03-2006 12:53 AM
PT6.9 MEMORY LEAK!!!!!! COME ON DIGI :( de_mix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 08-22-2005 02:36 PM
