Call it stereo or polyphonic?
I did not realize Pt could export 6 channel polyphonic files because the choice types are mono or stereo. I was exporting a 5.1 final mix audio file for a film and discovered this by mistake. It would be easier, I think if the Export files window included a blurb next to stereo (polyphonic).
Does anyone have any preference for which is the best delivery file type for final audio elements for 5.1 printmaster, stems, and M&E elements, if it is not specifically stated in specs? |
Re: Call it stereo or polyphonic?
Mono! Nothing else will be universally understood, I always deliver my 6tracks as mono files.
-- Jerome O'Donohoe - TV and Film audio post in London, UK and thereabouts. www.fade-up.com |
If you have a 5.1 master output set on Pro tools, it should export poliphonic files. But only bouncing to disk...
Mix Stage 1 PT HDX Ultimate 2022.12 D-Control HD I/O Hackintosh i9 12900K 32 Gb RAM OSX 12.6.7 Mix Stage 2 PT HDX2 Ultimate 2023.6 S6 MTRX I/O Hackintosh i7 8700K 32 Gb RAM OSX 12.6.7 Mix Stage 3 PT HDX Ultimate 2023.6 D-Command HD I/O Hackintosh i7 8700K 32 Gb RAM OSX 12.6.7 ADR PT MBox Studio Ultimate 2023 Mac Mini M1 8 Gb RAM OSX 13.4.1 Edit 1 PT HDN PCIe 2023.6 96 I/O Intel i7 6700K 32 Gb RAM.OS Windows 10 Estúdio JLS Facilidades Sonoras São Paulo - Brazil |
+1 I make mono prints too.
Any DAW apart from ProTools expects 5.1 poly files to be in AES track layout (L,R,C,Lf,Ls,Rs). ProTools can't handle these. So to be sure, I always export 5.1 Monophonic - less possibility of error.
Good to know that the PT poly files are non AES standard. I will stick to mono files for each channel.
Vacuum , any way to make it polyphonic ? | Willbloke | Pro Tools 9 | 25 | 01-11-2012 05:23 PM |
Can't get PT to record polyphonic aftertouch | Oli P | Pro Tools TDM Systems (Mac) | 21 | 02-11-2010 06:34 PM |
PT8 Polyphonic Algo improvments? | rdolmat | Pro Tools TDM Systems (Mac) | 4 | 12-20-2008 02:45 PM |
surround panner - how do i call up stereo panners? | Matt Chan | ICON & C|24 | 6 | 02-06-2007 09:50 AM |
Avid, Omf and polyphonic WAV files | Kuba Pietrzak | Post - Surround - Video | 2 | 05-23-2006 01:19 AM |
