Strike Question
Does any body know if it is possible to clear the Intensity and Complexity automation in Strike after the midi has been recorded? If so, how is it done? Any help would be appreciated. Thank You. |
Re: Strike Question
I would try re-recording with midi-merge the settings flat. But I'm McGyver - there's probably a real way.
Re: Strike Question
Thanks for that, Jim. I've already tried that process but it won't seem to overide the previous automation.I was hoping that,like Redrum in Reason for example, you could right click on any instrument or fader and clear the automation rather than re-record the whole drum track again.
Re: Strike Question
Do a search on the forum for a user named Wolfram, he knows everything about Strike, he works for A.I.R.
Re: Strike Question
wouldnt mind an answer to this one as well. have tried everything including several calls to digi tec support without any luck.
Re: Strike Question
You should be able to go to the automation view for the track and select:
(fxa) Strike>Intensity or Complexity Are you not seeing those available? |
Re: Strike Question
yes, can see them but editing them makes no difference to the original recording
Re: Strike Question
I found the intensity automation under the mod wheel playlist.
Mac Pro 8-core 2.26, 10.7.5, 002R BLA sig mod, PTLE 10.3.2 |
Strike and vst question | trajan24 | macOS | 3 | 03-13-2012 10:58 PM |
Strike question | sundaze | Virtual Instruments | 2 | 02-27-2010 02:53 AM |
Another Strike Question... | StinkyStan | Virtual Instruments | 1 | 05-11-2009 10:39 AM |
Strike question | oulablank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-01-2008 12:51 PM |
strike question | sykobilly65 | Virtual Instruments | 3 | 02-27-2008 09:59 AM |
