Old 10-06-2021, 09:30 AM
macmuse macmuse is offline
Default Can only certain automation points be selected together?
Scenario: you place points in your automation line, let's say some are toward the top of the lane, others are at the bottom, e.g. left, right panning, or high volume, low volume. In other DAWs you can marquee select just the bottom points to move them. or just a couple points, or just the top points, etc.
I can't see how to choose only the points I want in PT. If I do a select, it sweeps across the entire lane and I can't pick or differentiate between the top points and the bottom points, since the selection is entirely vertical which includes the entire lane top to bottom. I figure there must be some trick or tool that I'm unaware of because it's a common way of selecting. Thanks!
Old 10-06-2021, 11:49 AM
daeron80 daeron80 is offline
Default Re: Can only certain automation points be selected together?
I don't think so. PT has inherited its automation-point design from the early 90s. It would probably require a very deep rewrite of the software to get past that limitation. You're right that it's quite behind some other DAWs in this respect. It's one of the things I miss most from Reaper.
David J. Finnamore
Old 10-06-2021, 11:58 AM
EGS's Avatar
EGS EGS is offline
Tiny fixes or edits to those automation dots is painful for me almost every time...
Click for audio/video demo
Click for resume
How to marquee only certain automation points macmuse Avid Pro Mixing General Discussion 0 10-05-2021 06:52 AM
automation points fmilian Pro Tools HDX & HD Native Systems (Mac) 3 10-28-2014 08:54 PM
How to 'group' automation points? nilsk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-06-2008 12:36 PM
Automation points resolution ishur Pro Tools TDM Systems (Mac) 3 09-17-2006 02:30 PM
Keep losing automation points DEXTERITY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-18-2005 05:05 PM
